-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Just a small note about v.in.gpsbabel: when loading data to DB, if user
does not have sufficient permissions, he gets an error about db.login.
In fact, the problem can be solved both with db.login and db.connect, so
I think a more general statement would be more appropriate.
Should I fill a bug about this?
All the best.
pc
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFEqncf/NedwLUzIr4RAjMzAJ0QcHeXPuHQ456TZZT/XfUhWPWuswCfQY4A
bEk5gzVdzk98mZXt2J8lTws=
=9gzg
-----END PGP SIGNATURE-----
Hash: SHA1
Hi all.
Probably an error test is missing? Could you post the error message?
BTW: db.login is only needed for real DBMS'.
Aren't the authors in cc?
All the best.
pc
Paolo Cavallini
www.faunalia.it
=9gzg
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
