I grabbed the 2.0 version of gshhs, released 2009-07-15, but can’t import it into GRASS. The module doesn’t return much in terms of error information.
v.in.gshhs in=gshhs_f.b out=gshhs_f --o
Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
ERROR: Error reading data
I’ve tried the various levels of detail (f, h, i, l) with the same result. Based on the readme file there may be some internal changes, but these are beyond me. Any thoughts?
GSHHS 2.0 - http://www.soest.hawaii.edu/pwessel/gshhs/index.html
gshhs 2.0 is not yet supported, unfortunately. The latest supported version is 1.6, v.in.gshhs is awaiting updating.
Markus M
Jamie Adams wrote:
I grabbed the 2.0 version of gshhs, released 2009-07-15, but can't import it into GRASS. The module doesn't return much in terms of error information.
I've tried the various levels of detail (f, h, i, l) with the same result. Based on the readme file there may be some internal changes, but these are beyond me. Any thoughts?
- Jamie
grass-dev mailing list
grass-dev@lists.osgeo.org
I've updated v.in.gshhs, it supports now GSHHS data versions 1.4 through to 2.0, and issues an error if a version is not supported, telling exactly that, no more non-descript error reading data.
v.in.gshhs imports exported as shapefiles display now properly in QGIS, no more strange horizontal lines.
Please check out the new version and let me know if it doesn't work for you.
Markus M
- Jamie
That did the trick, thanks for the quick update!
On Fri, Aug 14, 2009 at 9:56 AM, Markus Metz <markus.metz.giswork@googlemail.com> wrote:
I’ve updated v.in.gshhs, it supports now GSHHS data versions 1.4 through to 2.0, and issues an error if a version is not supported, telling exactly that, no more non-descript error reading data.
Please check out the new version and let me know if it doesn’t work for you.
Markus M
