[GRASS-dev] v.in.lidar: limit the import to a set of polygons
in r66823 I’ve added a mask option to v.in.lidar. One can now import points only in areas specified by the 2D polygons (areas in GRASS) in the vector map. There is a flag -i to import point only outside of these areas. This adds nicely to the existing -r flag (import only in computational region) and spatial option (import only in rectangle specified in the option).
This new functionality overlaps with basic functionality of v.select. I don’t have a benchmark yet, but if nothing else, one saves some space by not storing the points for the second time before the spatial selection.
The import by areas can be combined with new additions to v.patch to merge two or more point clouds together.
Tested on some lidar and UAV LAS files, but I was not able to make an automated test yet.
Questions: Would raster map as mask make sense in an additional option? Should there be a flag to respect the raster mask? Should the vector map be accompanied by typical where and cats options (perhaps in a guisection Spatial) or would this make the interface too complicated?
I’m attaching also list of recent improvements related to the point cloud support if anybody would like to follow up on that.
Vaclav
v.in.lidar: import points only in selected areas
https://trac.osgeo.org/grass/changeset/66823
https://grass.osgeo.org/grass71/manuals/v.in.lidar.html
v.patch: flags to work without topology and with z
https://trac.osgeo.org/grass/changeset/66822
v.in.lidar: decimation (skip, preserve, offset, limit)
https://lists.osgeo.org/pipermail/grass-dev/2015-September/076275.html
v.in.lidar: store return or class as category
https://lists.osgeo.org/pipermail/grass-dev/2015-September/076490.html
v.decimate: point cloud decimation of native vector maps
https://lists.osgeo.org/pipermail/grass-dev/2015-September/076562.html
(not yet enabled in the parent Makefile)
r.in.lidar: read multiple LAS files in one run
https://lists.osgeo.org/pipermail/grass-dev/2015-October/077006.html
r.in.lidar: height above ground
https://lists.osgeo.org/pipermail/grass-dev/2015-September/076147.html
https://lists.osgeo.org/pipermail/grass-dev/2015-October/076759.html
#2732: Read lidar data as vector points using PDAL
https://trac.osgeo.org/grass/ticket/2732
#2472: v.in.lidar gives negative point count on large las files
https://trac.osgeo.org/grass/ticket/2472#comment:4
https://trac.osgeo.org/grass/ticket/2472#comment:5
Using layers and categories for something else than ID and class
https://lists.osgeo.org/pipermail/grass-dev/2015-September/076552.html
