[GRASS-dev] v.in.ogr and v.import do not import all features in gpkg file
Hello devs
I found a quite striking issue when importing a simple vector file. It is a gpkg file with 30 points and only one field as attribute. When I import it into GRASS, either with v.in.ogr or v.import, I only get 28 points imported. No idea why. Meanwhile, ogrinfo -al reports 30 points, same as QGIS
v.in.ogr input=central.gpkg layer=central output=central
Check if OGR layer contains polygons…
WARNING: Vector map already exists and will be overwritten
Creating attribute table for layer …
Importing 28 features (OGR layer )…
Building topology for vector map central@testing
Registering primitives…
v.db.select -c central | wc -l
28
I attach the file.
Thanks much in advance
Vero
ps: I use trunk r73492
(attachments)
central.gpkg (116 KB)
A follow up:
If I convert the gpkg to shapefile and import into GRASS, then all points are imported:
v.import input=central.shp layer=central output=central --overwrite
Importing 30 features (OGR layer )…
Input <central.shp> successfully imported without reprojection
30
What could be the problem with gpkg and how to test further??
El lun., 8 oct. 2018 a las 21:24, Veronica Andreo (<veroandreo@gmail.com>) escribió:
Hello devs
28
I attach the file.
Vero
On Tue, Oct 9, 2018 at 2:11 PM Veronica Andreo <veroandreo@gmail.com> wrote:
A follow up:
30
The problem is that the bounding box included in the gpkg does not cover all points: these missing 2 points are outside the bbox embedded in the gpkg. As a safety measure, v.in.ogr applies a spatial filter using the input layer’s bbox to exclude corrupt features (previously observed in some shapefiles). This spatial filter is passed directly to OGR and as a consequence, OGR provides only 28 and not 30 points to v.in.ogr.
I am not sure what to do about this. Disable this safety check again?
Markus M
Hello devs
28
I attach the file.
Vero
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Markus,
Many thanks for your answer :slight_smile:
El mar., 9 oct. 2018 a las 19:42, Markus Metz (<markus.metz.giswork@gmail.com>) escribió:
A follow up:
30
And how is this bounding box created/defined, I was not aware of it.
I only converted from .kml to gpkg and then imported into GRASS.
Maybe the bb safety check makes sense for features other than points, dunno. Others can for sure tell some use cases that I am not aware of. But I can say that it is pretty striking to see that some features are “eaten and lost” when importing into GRASS while ogr and others show everything.
What about a flag? Import all by default and the safety check with a flag? Or at least a note in the manual page of v.in.ogr
many thanks again :slight_smile:
Vero
Hi Vero and Markus,
Maybe the bb safety check makes sense for features other than points, dunno. Others can for sure tell some use cases that I am not aware of. But I can say that it is pretty striking to see that some features are "eaten and lost" when importing into GRASS while ogr and others show everything.
My two cents' worth: from my perspective as a user, the main problem
is that it drops points without a warning (most of the time I am
blissfully unaware of the exact number of features that need import).
So throwing a warning should be considered, with maybe a flag as
suggested by Vero to void that check.
P
On Tue, Oct 9, 2018 at 8:32 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Markus,
A follow up:
30
It is created by the software that created that layer.
In this case something must have gone wrong when converting from kml to gpkg.
I would rather disable this safety check if it does more harm than good.
Markus M
Vero
Hola :slight_smile:
El mié., 10 oct. 2018 a las 15:04, Markus Metz (<markus.metz.giswork@gmail.com>) escribió:
Hi Markus,
A follow up:
30
+1
Vero
trešd., 2018. g. 10. okt., plkst. 16:04 — lietotājs Markus Metz
(<markus.metz.giswork@gmail.com>) rakstīja:
I would vote for:
1) adding a flag to activate safety check;
2) disable safety check by default;
3) add a check "point in bbox" during import and print a warning if
any point of any geometry is outside of bbox (aka safety check without
action).
Markus M
Māris.
I have disabled this safety check in trunk r73522.
I would vote for:
  1. adding a flag to activate safety check;
  2. disable safety check by default;
  3. add a check “point in bbox” during import and print a warning if
action).
In this case there should also be a check “line in bbox” and “polygon in bbox”.
Right now we let OGR do all the spatial filtering which works just fine, often using features of the underlying vector format. I would prefer to leave this to OGR and not do this in GRASS.
Markus M
Markus M
Māris.
