[GRASS-dev] v.in.ogr eats all memory
importing a big SHAPE file, it appeared that most
of the operating was shifted to swap space (Linux). I
had to reboot the machine (no remote login, not even
caplock worked).
Question: Can we add some test to avoid that more
than xx percent of the memory are used? There won't
be any hot plugin of extra RAM, so v.in.ogr should
exit with memory allocation error. I just wonder why
the kernel doesn't take care.
caplock worked).
Usually you can get away with remote login if it is X that locked up,
with a frozen kernel you have less options.. ctrl-alt-F1 sometimes?
attempt G_malloc(),G_free() of estimated size before processing. Back in
the mailing list archives somewhere I figured out the current bytes per
vector point needed (with valgrind) and suggested this?
I don't know how to query available memory in a cross platform way.
I just wonder why the kernel doesn't take care.
Hamish
Hello Markus,
On Thu, 18 May 2006 18:29:18 +0200 Markus Neteler <neteler@itc.it>
wrote:
caplock worked).
Second that.
Had that with a large OCI-dataset all the time and was wondering why
this works on one maschine (1GB RAM) and not on anotherone (256MB
RAM)...
I would also like to see such a feature. I have run that through
valgrind, perhaps someone more knowledgeable could have a look at it?
I have provided it here:
http://www.gdf-hannover.de/~holl/tmp/valgrind_v.in.ogr.log.pid26607
Best regards
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
caplock worked).
The ssh daemon was no longer responding (I waited only some minutes,
though) and
the keyboard also dead (no capslock light, no ctrl-alt-F1,nothing).
Eg. the 'top' application knows it
Mem: 2058056k total, 2013328k used, 44728k free, 452900k buffers
Swap: 4192888k total, 0k used, 4192888k free, 295372k cached
so there must be a way.
$ cat /proc/meminfo
but what about on cygwin? mac? solaris?
Hamish
That won't necessarily help.
The underlying brk/sbrk (or mmap(MAP_ANONYMOUS)) call will succeed so
long as there is sufficient virtual memory and you don't exceed any
usage limits which are in force.
That doesn't mean that reading/writing the allocated memory won't
cause the system to go into a swapping frenzy.
Back in
The "free" command will give you some global memory statistics.
However, that information is practically meaningless to an
application, as there is no way to figure out how much of that memory
you can reasonably expect to use.
On a lightly-loaded system, the application can expect to be able to
use all of the memory which is currently being used by the buffer
cache (which is usually most of the total memory). On a heavily-loaded
system, it may only be able to use a small fraction of it.
Hello developers,
On Fri, 19 May 2006 16:20:47 +0100 Glynn Clements
> Back in
> per vector point needed (with valgrind) and suggested this?
To keep this problem in mind I have added a bug in bugtracker[1]
so that we do not forget it.
If anybody feels responsible to fix this anoying problem, please go
ahead :slight_smile:
It seems that building topology needs lot of memory though.
Best regards
  Stephan
[1] https://intevation.de/rt/webrt?display=History&serial_num=4564
Is it possible to read multiple tables from postgis (postgresql) into grass with v.in.ogr? I seem to be able to only read in the table that contains the geometry data. I tried creating a postgresql view that contains all the columns (from multiple tables) that I need, however, v.in.ogr does not seem to see the view.
