[GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Hi
When I try to to import a vector map containing (lots of) lines from a
certain schema in a PostGIS-database, i get the following error messages:
While other formats with the same data work just fine:
This gave no errors...
I was using GRASS 7 (compiled about a month ago) and PostGIS 2.0.1 /
PostgreSQL 9.1 on Ubuntu 12.04 LTS Server.
Looks like something got mixed up in the insert statement. Is that a known
issue or shall I file a ticket?
Stefan
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-ogr-fails-to-import-from-PostGIS-with-schema-tp5057034.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Hi Markus
Sorry, good to know. It was HTML indeed.
So here is the problem-description in plain ASCII:
When I try to import a vector map containing (lots of) lines from a certain schema in a PostGIS-database, i get the following error messages:
v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_lines" output="Test"
DBMI-SQLite driver error:
Error in sqlite3_prepare():
unrecognized token: "3insert"
ERROR: Cannot insert new row: insert into Test values ( 3insert into Test
       values ( 3, NULL, NULL, NULL, NULL, NULL, NULL, 'FiktivDelelinje',
       '1000-01-01 0:00:00', NULL, 101 )
ogr2ogr -f SQLite /home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite "PG:host=myserver dbname=gisdata" n50_2013_utm33n.n50_2013_arealdekke_lines
v.in.ogr dsn=/home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite output="N50_2013_arealdekke_lin"This gave no errors...
Forgot to mention in my earlier post, that also importing polygons from the same PostGIS database (and schema) as the lines works fine:
v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_polygons" output="Test_pol"
Gave no error messages either...
So, maybe it is something with the geometry type?
Stefan
-----Original Message-----
From: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] On Behalf Of Markus Neteler
Sent: 31. mai 2013 00:22
To: Blumentrath, Stefan
Subject: Re: [GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Hi Stefan,
you message (HTML?) did not contain the relevant error... see below.
It is better to send in pure ASCII...
Best
On Thu, May 30, 2013 at 9:51 PM, SBL <Stefan.Blumentrath@nina.no> wrote:
Hi
known issue or shall I file a ticket?
Stefan
GIS-with-schema-tp5057034.html Sent from the Grass - Dev mailing list
grass-dev mailing list
grass-dev@lists.osgeo.org
Dear all
I am reposting this message, because the problem, that I cannot import lines from PostGIS is still present in GRASS 7 svn-revision 57009 (and in 6.4.3svn (older revision) too.)
Do you think this is only due to my PostGIS og GDAL/OGR installation, or shall I file a ticket?
Another (much less important) thing here is, that the status message says:
"Counting polygons for 6125184 features (OGR layer
<n50_2013_utm33n.n50_2013_arealdekke_lines>)..."
although the layer only contains (6125184) lines...
Stefan
From: grass-dev-bounces@lists.osgeo.org [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Blumentrath, Stefan
Sent: 31. mai 2013 08:27
To: Markus Neteler; grass-dev@lists.osgeo.org
Hi Markus
Stefan
Hi Stefan,
Best
Hi
Stefan
On Fri, Jul 5, 2013 at 10:02 AM, Blumentrath, Stefan
Dear all
Please try trunk r57016. If this works for you, the changes should be
backported.
The module only knows if a layer only contains lines after it went
through all features. In this case the polygon count will be zero.
Unless you use v.in.ogr type=boundary in which case lines will be
converted to boundaries.
Markus M
Stefan
Hi Markus
Stefan
Hi Stefan,
Best
Hi
Stefan
Thanks Markus!
It works now.
Regarding the status message: I just found it a bit confusing, not more than that...
Stefan
From: Markus Metz [mailto:markus.metz.giswork@gmail.com]
Sent: 5. juli 2013 10:51
Cc: grass-dev@lists.osgeo.org
On Fri, Jul 5, 2013 at 10:02 AM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
Dear all
lines from PostGIS is still present in GRASS 7 svn-revision 57009 (and in 6.4.3svn (older revision) too.) Do you think this is only due to my PostGIS og GDAL/OGR installation, or shall I file a ticket?
Please try trunk r57016. If this works for you, the changes should be backported.
The module only knows if a layer only contains lines after it went through all features. In this case the polygon count will be zero.
Unless you use v.in.ogr type=boundary in which case lines will be converted to boundaries.
Markus M
Stefan
Stefan
schema
Hi Markus
Stefan
schema
Hi Stefan,
Best
Hi
Stefan
t GIS-with-schema-tp5057034.html Sent from the Grass - Dev mailing
On Fri, Jul 5, 2013 at 11:25 AM, Blumentrath, Stefan
Thanks Markus!
It works now.
OK, backported to 6.5 and 6.4 in r57017/8.
Changed in trunk to
"Check if OGR layer <n50_2013_utm33n.n50_2013_arealdekke_lines>
contains polygons..."
Markus M
Stefan
Dear all
Markus M
Stefan
Stefan
schema
Hi Markus
Stefan
schema
Hi Stefan,
Best
Hi
Stefan
