we found a serious bug when importing polygons from a PostgreSQL/PostGIS db: resultant areas might have wrong attributes because of a mix-up of the connection from geometries to attributes. This bug has been fixed in master and relbr78 (a new release of GRASS 7.8 should probably come out soon).
Apparently this bug only affects those OGR datasources with a client/server database system, e.g. PostgreSQL or MySQL.
This bug does not affect common file-based formats like shapefile, geopackage, etc.
Markus M
