I did a change in v.in.osm adding a c flag to cleanup the data and
create a GRASS GIS network topological correct, this is done by
default now. I attached a diff.
The flag could be also the opposite, so don't cleanup the data.
What do you think?
ciao
Luca
www.lucadelu.org
(attachments)
v.in.osm.diff (2.47 KB)
On 09/02/17 10:20, Luca Delucchi wrote:
What do you think?
I would not make it the default. You cannot be sure that users want to clean in the same way you do, so better to provide it as an (well-documented) option.
Moritz
I incline to clean up the data as a default. The module should behave in a user-friendly way therefore expected behavior should be the default one.
I guess that most users would expect to import the data in topologically correct format. If the topology is wrong, a user can get totally misleading results (wrongly assuming they are correct) from various vector modules which is not very nice.
Stepan
---------- Původní zpráva ----------
Od: Moritz Lennert mlennert@club.worldonline.be
Komu: Luca Delucchi lucadeluge@gmail.com, GRASS-dev grass-dev@lists.osgeo.org
Datum: 9. 2. 2017 13:47:49
Předmět: Re: [GRASS-dev] v.in.osm
The flag could be also the opposite, so don’t cleanup the data.
What do you think?
Moritz
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
