Hi devs,
I tried v.info using layer option but I cannot see any differences, I
notice also that is possible to use any character and it doesn't
return any error, you could also set layer=a and it return the same
value.
Do you have the same behavior?
ciao
Luca
www.lucadelu.org
Hi Luca,
apparently [0] the layer option is only needed for v.info -c (Print
types/names of table columns for specified layer instead of info and
exit). What information about a vector do you want to get? Note that
vector objects (points, lines, boundaries, areas) are always present,
even if they are not linked to a layer at all. Maybe v.category
option=report is more appropriate for your needs?
A question like this should rather go to the user ml.
Markus M
[0] https://grass.osgeo.org/grass71/manuals/v.info.html
On Thu, May 26, 2016 at 4:06 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi devs,
value.
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On 26 May 2016 at 23:21, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hi Luca,
Hi Markus
yes v.category is the right answer, thanks
yes I suppose it, so I'm going to register there
Markus M
ciao
Luca
www.lucadelu.org
