v.kernel should not use Vect_check_input_output_name for output
because output is raster.
Radim
Radim
output is both raster and vector,
out_opt->description = _("output raster/vector map");
and then there's this:
if( !flag_q->answer ) {
Vect_open_new (&Out, out_opt->answer, 0);
Vect_hist_command ( &Out );
Vect_write_line ( &Out, GV_LINE, SPoints, SCats );
Vect_build (&Out, stderr);
Vect_close (&Out);
Hamish
On 10/10/06, Hamish <hamish_nospam@yahoo.com> wrote:
> because output is raster.output is both raster and vector,
Yes, you are right, it should only be checked if net is used.
Radim
Vect_close (&Out);Hamish
