[GRASS-dev] v.krige error
Hi list,
I would like to test new module v.krige, but after launchig I get error:
  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 419, in <module>
    sys.exit(main(argv = grass.parser()))
  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 386, in main
    logger = grass)
  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 265, in Run
    globals()["InputData"] = self.ImportMap(input, column)
  File "/usr/local/grass-6.5.svn/scripts/v.krige", line 164, in
ImportMap
    coordinatesDF = robjects.r['data.frame'](x =
coordinatesPreDF.r['coords.x1'][0],
AttributeError: 'DataFrame' object has no attribute 'r'
Rpy2 is installed, Opensuse 11.2,
Its my mistake or bug in module?
thanks
Jan Trochta
On Tue, Mar 16, 2010 at 11:58 AM, Jan Trochta <j.trochta@gmail.com> wrote:
Hi list,
logger = grass)
ImportMap
Hi Jan,
it's a bug in the module - not known to me until now, but
unfortunately I never tested v.krige on opensuse.
At the moment the module is working on GRASS trunk and afaik on 6.5
branch, except for the plot popup window.
Thanks for the report and sorry for inconvenience... will look at it asap.
all the best,
Anne
thanks
Jan Trochta
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks for helping,
If you will need testing or anything post me mail..
Jan
Anne Ghisla píše v Út 16. 03. 2010 v 12:17 +0200:
> Hi list,
> logger = grass)
> ImportMap
Hi Jan,
all the best,
Anne
> thanks
> Jan Trochta
