[GRASS-dev] v.net.path issue report
Hi all, I’ve been sharing the v.net.path issue I’ve experiência to the User’s list with no reply.
After trying the command in two windows versions, it seems to me it is a GRASS core issue that should be reported.
Here is the description below.
I’ve tried v.net.path over a line network (one branch only) I built using “v.net -c operation=nodes” over win7 and win8.
v.net.path cannot get finished and stays long and long showing the message “Building graph… Registering arcs…”
I have more details as long as you ask me.
A lot of thanks.
Jose
On 15/12/15 15:38, José Anderson wrote:
Hi all, I've been sharing the v.net.path issue I've experiência to the
User's list with no reply.
I've tried v.net.path over a line network (one branch only) I built
using "v.net <http://v.net> -c operation=nodes" over win7 and win8.
message "Building graph... Registering arcs..."
Can you reproduce this with the North Carolina Demo dataset ? This would allow others to test. Or make your data available somehow ?
Moritz
Hello,
[Please keep communication on the list]
Testing with your data on GNU/Linux I cannot reproduce the problem:
time v.net -c input=palmitalmainApiaiNetout operation=nodes out=test_network --o
real 0m0.936s
user 0m0.052s
sys 0m0.028s
I currently don't have a running Windows installation available to test there, so please post a bug report on https://trac.osgeo.org/grass/, if possible with the data.
Moritz
On 15/12/15 17:50, José Anderson wrote:
M,
thanks a lot for asking. I appreciate that.
Here comes the GRASS location zipped. There is only the line network I
earned from v.net <http://v.net> (palmitalmainApiaiNetout@PERMANENT).
I hope to hear from you soon.
J
Em ter, 15 de dez de 2015 às 09:12, Moritz Lennert
<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>
escreveu:
     > Hi all, I've been sharing the v.net.path issue I've experiência
    to the
     > User's list with no reply.
     > After trying the command in two windows versions, it seems to me
    it is a
     > GRASS core issue that should be reported.
     > Here is the description below.
     > I've tried v.net.path over a line network (one branch only) I built
     > using "v.net <http://v.net> <http://v.net> -c operation=nodes"
    over win7 and win8.
     > v.net.path cannot get finished and stays long and long showing the
     > message "Building graph... Registering arcs..."
     > I have more details as long as you ask me.
    Moritz
Motiz.
I really appreciated your effort in colaborate to this v.net.path test.
So far, it seems v.net.path is not working properly for windows precompiled GRASS 7.0.
I’m going ahead and provide for myself a linux PC to repeat the test.
Thank you so much.
José
Em sex, 18 de dez de 2015 03:58, Moritz Lennert <mlennert@club.worldonline.be> escreveu:
Hello,
real 0m0.936s
user 0m0.052s
sys 0m0.028s
I currently don’t have a running Windows installation available to test
Moritz
M,
J
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>
escreveu:
to the
it is a
using “v.net <http://v.net> <http://v.net> -c operation=nodes”
over win7 and win8.
Moritz
