(moving to grass-dev)
[Martina - we need to investigate a bit]
On Wed, Apr 15, 2009 at 10:42 PM, Martina Schäfer
<Martina.Schafer@ebc.uu.se> wrote:
Interesting discussion!! I've created the centroids but unfortunately, the
visibility network module repeatedly crashed (I am using GRASS 6.4 on Mac
OS, but tried on Windows XP as well) with the message "out of memory".
I have run valgrind to check for a memory leak (Linux 64 bit box):
Some funky "uninitialised byte(s)" problem appears... (inline also a
debug msg?):
GRASS 6.5.svn (spearfish60): > CMD="v.net.visibility input=roads
output=graph --o"
GRASS 6.5.svn (spearfish60): > valgrind --tool=memcheck
--leak-check=yes --show-reachable=yes $CMD --o
==3496== Memcheck, a memory error detector.
==3496== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==3496== Using LibVEX rev 1854, a library for dynamic binary translation.
==3496== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==3496== Using valgrind-3.3.1, a dynamic binary instrumentation framework.
==3496== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==3496== For more details, rerun with: -v
==3496==
==3496== Syscall param write(buf) points to uninitialised byte(s)
==3496== at 0x7035D70: write (in /lib64/libc-2.8.so)
==3496== by 0x6FD6EE9: _IO_file_write (in /lib64/libc-2.8.so)
==3496== by 0x6FD7DF8: _IO_do_write (in /lib64/libc-2.8.so)
==3496== by 0x6FD89F6: _IO_switch_to_get_mode (in /lib64/libc-2.8.so)
==3496== by 0x6FD736F: _IO_file_seekoff (in /lib64/libc-2.8.so)
==3496== by 0x6FCCDA9: ftell (in /lib64/libc-2.8.so)
==3496== by 0x5D41F4D: dig_ftell (file.c:40)
==3496== by 0x5D42963: dig__write_head (head.c:56)
==3496== by 0x4E57FE4: V1_open_new_nat (open_nat.c:127)
==3496== by 0x4E57434: Vect_open_new (open.c:565)
==3496== by 0x402EAF: main (main.c:85)
==3496== Address 0x4028009 is not stack'd, malloc'd or (recently) free'd
Building topology for vector map <graph>...
Registering primitives...
330643 primitives registered
661286 vertices registered
primitives: 402.000000
Building areas...
100%
0 areas built
0 isles built
areas: 1.000000
Attaching islands...
isles: 0.000000
Attaching centroids...
100%
centroids: 1.000000
areas to cidx: 0.000000 <<--- should this be G_debug()?
Number of nodes: 4491
Number of primitives: 330643
Number of points: 0
Number of lines: 330643
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
==3496==
==3496== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 2 from 1)
==3496== malloc/free: in use at exit: 489,152,702 bytes in 2,067,875 blocks.
==3496== malloc/free: 4,047,776 allocs, 1,979,901 frees, 1,604,422,635
bytes allocated.
==3496== For counts of detected errors, rerun with: -v
==3496== searching for pointers to 2,067,875 not-freed blocks.
==3496== checked 73,330,480 bytes.
==3496==
==3496==
==3496== 192 bytes in 8 blocks are possibly lost in loss record 1 of 21
==3496== at 0x4C2136E: malloc (vg_replace_malloc.c:207)
==3496== by 0x529603E: G__malloc (alloc.c:41)
==3496== by 0x4E3E213: Vect__new_cats_struct (cats.c:62)
==3496== by 0x4E3E1C4: Vect_new_cats_struct (cats.c:44)
==3496== by 0x404EB4: report (visibility.c:212)
==3496== by 0x404E5B: handle (visibility.c:198)
==3496== by 0x4050E7: construct_visibility (visibility.c:278)
==3496== by 0x4030EF: main (main.c:125)
==3496==
==3496==
==3496== 256 bytes in 8 blocks are still reachable in loss record 2 of 21
==3496== by 0x4E4F2F2: Vect__new_line_struct (line.c:69)
==3496== by 0x4E4F2A8: Vect_new_line_struct (line.c:59)
==3496== by 0x404EAB: report (visibility.c:211)
==3496== by 0x404C70: handle (visibility.c:176)
==3496==
==3496==
==3496== 480 bytes in 15 blocks are possibly lost in loss record 3 of 21
==3496==
==3496==
==3496== 480 bytes in 1 blocks are still reachable in loss record 4 of 21
==3496== by 0x5296135: G__realloc (alloc.c:109)
==3496== by 0x4E46602: Vect_add_dblink (field.c:226)
==3496== by 0x4E47333: Vect_read_dblinks (field.c:645)
==3496== by 0x4E56D61: Vect__open_old (open.c:344)
==3496== by 0x4E57029: Vect_open_old (open.c:415)
==3496== by 0x402E5F: main (main.c:81)
==3496==
==3496==
==3496== 2,048 bytes in 4 blocks are definitely lost in loss record 5 of 21
==3496== by 0x5F545D6: RTreeNewNode (node.c:49)
==3496== by 0x5F5364C: RTreeNewIndex (index.c:29)
==3496== by 0x5D4B522: dig_spidx_init (spindex.c:36)
==3496== by 0x5D43C94: dig_init_plus (plus.c:94)
==3496== by 0x4E564B2: Vect__open_old (open.c:146)
==3496==
==3496==
==3496== 4,800 bytes in 6 blocks are indirectly lost in loss record 6 of 21
==3496== at 0x4C1F144: calloc (vg_replace_malloc.c:397)
==3496== by 0x5D3FAF5: dig__frealloc (allocation.c:144)
==3496== by 0x5D3F991: dig__alloc_space (allocation.c:83)
==3496== by 0x5D4D3C9: dig_alloc_points (struct_alloc.c:239)
==3496== by 0x4E5B200: Vect__Read_line_nat (read_nat.c:309)
==3496== by 0x4E5AD24: V2_read_line_nat (read_nat.c:138)
==3496== by 0x4E5A9E3: Vect_read_line (read.c:106)
==3496== by 0x403403: count (main.c:200)
==3496== by 0x402FE6: main (main.c:108)
==3496==
==3496==
==3496== 33,700 bytes in 85 blocks are still reachable in loss record 7 of 21
==3496== by 0x5D3F976: dig__alloc_space (allocation.c:81)
==3496== by 0x5D4983D: buf_alloc (portable.c:55)
==3496== by 0x5D49B0E: dig__fread_port_L (portable.c:150)
==3496== by 0x5D4872D: dig_Rd_Plus_head (plus_struct.c:614)
==3496== by 0x4E579D6: Vect_open_topo (open.c:722)
==3496== by 0x4E5693A: Vect__open_old (open.c:229)
==3496==
==3496==
==3496== 38,440 bytes in 1,356 blocks are still reachable in loss
record 8 of 21
==3496== by 0x4C214F7: realloc (vg_replace_malloc.c:429)
==3496== by 0x5D4D0A8: dig_alloc_nodes (struct_alloc.c:99)
==3496== by 0x5D44166: dig_load_plus (plus.c:290)
==3496== by 0x4E57AC5: Vect_open_topo (open.c:751)
==3496==
==3496==
==3496== 40,008 bytes in 1 blocks are still reachable in loss record 9 of 21
==3496== at 0x4C214A1: realloc (vg_replace_malloc.c:429)
==3496== by 0x5D46D50: dig_add_node (plus_node.c:116)
==3496== by 0x5D461D1: add_line (plus_line.c:55)
==3496== by 0x5D46379: dig_add_line (plus_line.c:114)
==3496== by 0x4E3CB9B: Vect_build_nat (build_nat.c:538)
==3496== by 0x4E3AD22: Vect_build_partial (build.c:134)
==3496== by 0x4E3AC15: Vect_build (build.c:55)
==3496== by 0x40314C: main (main.c:132)
==3496==
==3496==
==3496== 223,200 bytes in 558 blocks are possibly lost in loss record 10 of 21
==3496== by 0x5D4D415: dig_alloc_points (struct_alloc.c:248)
==3496== by 0x4E4F3CA: Vect_copy_xyz_to_pnts (line.c:118)
==3496== by 0x404F16: report (visibility.c:219)
==3496==
==3496==
==3496== 248,016 bytes in 5,167 blocks are still reachable in loss
record 11 of 21
==3496== by 0x5D4CF59: dig_alloc_node (struct_alloc.c:44)
==3496== by 0x5D46D93: dig_add_node (plus_node.c:123)
==3496==
==3496==
==3496== 449,309 bytes in 66 blocks are still reachable in loss record
12 of 21
==3496== by 0x52CE929: G_store (store.c:36)
==3496== by 0x52C29D9: G_set_program_name (progrm_nme.c:52)
==3496== by 0x52AEAD2: G__gisinit (gisinit.c:51)
==3496== by 0x402CD7: main (main.c:42)
==3496==
==3496==
==3496== 2,645,144 bytes in 4,491 blocks are still reachable in loss
record 13 of 21
==3496== by 0x5D4CFF9: dig_node_alloc_line (struct_alloc.c:72)
==3496== by 0x5D46B28: dig_node_add_line (plus_node.c:56)
==3496== by 0x5D46079: add_line (plus_line.c:44)
==3496==
==3496==
record 14 of 21
==3496== by 0x5D4D033: dig_node_alloc_line (struct_alloc.c:77)
==3496== by 0x5D4622F: add_line (plus_line.c:64)
==3496==
==3496==
==3496== 2,648,008 bytes in 1 blocks are still reachable in loss
record 15 of 21
==3496== by 0x5D4D15B: dig_alloc_lines (struct_alloc.c:133)
==3496== by 0x5D46344: dig_add_line (plus_line.c:110)
==3496==
==3496==
==3496== 4,020,168 bytes in 3 blocks are still reachable in loss
record 16 of 21
==3496== by 0x5296148: G__realloc (alloc.c:111)
==3496== by 0x52A4EB2: set_env (env.c:156)
==3496== by 0x52A4C44: read_env (env.c:104)
==3496== by 0x52A54CE: G__getenv (env.c:317)
==3496== by 0x52A5410: G_getenv (env.c:271)
==3496== by 0x52B36A0: G_location (location.c:63)
==3496== by 0x52B36B8: G__location_path (location.c:78)
==3496== by 0x52B3644: G_location_path (location.c:41)
==3496== by 0x52AEB0B: G__gisinit (gisinit.c:57)
==3496==
==3496==
==3496== 7,937,917 (7,937,869 direct, 48 indirect) bytes in 330,646
blocks are definitely lost in loss record 17 of 21
==3496== by 0x404B61: handle (visibility.c:164)
==3496==
==3496==
==3496== 26,517,440 bytes in 331,468 blocks are still reachable in
loss record 18 of 21
==3496== by 0x5D4D0F9: dig_alloc_line (struct_alloc.c:114)
==3496== by 0x5D45F40: add_line (plus_line.c:27)
==3496==
==3496==
==3496== 407,100,768 (10,579,968 direct, 396,520,800 indirect) bytes
in 330,624 blocks are definitely lost in loss record 19 of 21
==3496==
==3496==
==3496== 34,601,984 bytes in 67,582 blocks are still reachable in loss
record 20 of 21
==3496== by 0x5F56AF6: RTreeSplitNode (split_q.c:313)
==3496== by 0x5F54E52: RTreeAddBranch (node.c:201)
==3496== by 0x5F53BA3: RTreeInsertRect2 (index.c:121)
==3496== by 0x5F5398A: RTreeInsertRect2 (index.c:102)
==3496== by 0x5F53D81: RTreeInsertRect1 (index.c:162)
==3496==
==3496==
==3496== 396,516,048 bytes in 991,294 blocks are indirectly lost in
loss record 21 of 21
==3496==
==3496== LEAK SUMMARY:
==3496== definitely lost: 18,519,885 bytes in 661,274 blocks.
==3496== indirectly lost: 396,520,848 bytes in 991,300 blocks.
==3496== possibly lost: 223,872 bytes in 581 blocks.
==3496== still reachable: 73,888,097 bytes in 414,720 blocks.
==3496== suppressed: 0 bytes in 0 blocks.
Looks like some memory leak?
E.g.,
data_structures.c: stack = G_malloc(size * sizeof(struct Point));
but there is no G_free(stack).
In visibility.c I also see two malloc() calls instead of G_malloc().
