[GRASS-dev] v.out.kml: calling for betatesters
Hello,
there is a new add-on script to create KML from GRASS vectors.
It is available at
http://grasslab.gisix.com/scripts/v.out.kml/
and also linked under
http://grass.gdf-hannover.de/wiki/GRASS_AddOns
It works pretty good for me, but please send feedback if things need to be improved.
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
small typo on the web page:
The requested URL /scripts/v.out.kml/v.out.kml.sh/ was not found on this
server.
final / should be removed.
pc
peter.loewe@gmx.de ha scritto:
Hello,
It is available at
Peter
Paolo Cavallini
http://www.faunalia.it/pc
Peter,
I was looking for that, thanks. I have tested it against the new nc_spm_05 mapset with both NO success and success (see link below) and the following error twice
icontransparency=255/Applications/GRASS-6.3.app/Contents/Resources/scripts/v.out.kml.sh: line 471: ${$THE_OGR_PATH}: bad substitution
First from the popup menu
v.out.kml.sh -l map=roadsmajor@PERMANENT output=/Users/adiez/Desktop/pruebakmloutgrass.kml color=00:200:00 transparency=255 fcolor=00:100:00 ftransparency=255 size=1 iconcode=1 iconpalette=1 iconcolor=00:200:00 icontransparency=255
Location latlon_location_8464 created!
Input Projection Parameters: +proj=lcc +lat_1=34.33333333333334 +lat_2=36.16666666666666 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0 +no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Re-projecting vector map…
WARNING: Default driver / database set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
dbmi: Protocol error
WARNING: Cannot create new table
WARNING: Cannot copy table
Building topology …
355 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 266
Number of primitives: 355
Number of points : 0
Number of lines : 355
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
ERROR: Could not find input vector map roadsmajor@PERMANENT
-f KML /Users/adiez/Desktop/pruebakmloutgrass.kml.raw roadsmajor@PERMANENT.sh
/Applications/GRASS-6.3.app/Contents/Resources/scripts/v.out.kml.sh: line 571: FAILURE:: command not found
ERROR: aborted.
Then from cli, after copying roadsmajor@PERMANENT to roadmajors at current mapset
v.out.kml.sh -l map=roadsmajorc output=/Users/adiez/Desktop/pruebakmloutgrass.kml color=00:200:00 transparency=255 fcolor=00:100:00 ftransparency=255 size=1 iconcode=1 iconpalette=1 iconcolor=00:200:00 icontransparency=255/Applications/GRASS-6.3.app/Contents/Resources/scripts/v.out.kml.sh: line 471: ${$THE_OGR_PATH}: bad substitution
Location latlon_location_8938 created!
driver: dbf
Building topology …
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of areas : 0
Number of isles : 0
Exporting 355 points/lines…
100%
355 features written
-f KML /Users/adiez/Desktop/pruebakmloutgrass.kml.raw roadsmajorc.sh
See for results, in green grass kml
http://www.uv.es/adiez/images/grassoutkml.png
On Jul 10, 2007, at 9:53 AM, peter.loewe@gmx.de wrote:
Hello,
It is available at
Peter
Dr. Peter Löwe
grass-dev mailing list
grass-dev@grass.itc.it
