[GRASS-dev] v.patch process error: "Process ended with non-zero return code -9. "
I’m running v.patch on a large data set.
I’m connected to postgresql.
here is the error:
grass.exceptions.CalledModuleError: Module run None [‘v.patch’, ‘–o’, ‘-e’, ‘input=fraf10___________nw,fraf11___________nw,fraf12___________nw,fraf13___________nw,fraf14___________nw,fraf15___________nw,fraf16___________nw,fraf17___________nw,fraf18___________nw,fraf19___________nw,fraf20___________nw,fraf21___________nw,fraf22___________nw,fraf23___________nw,fraf24___________nw’, ‘output=fraf_patch’]
ended with error
Process ended with non-zero return code -9. See errors in the (error) output.
could you tell me how to solve the problem or which error is “-9”
many thanks
Grazia
2015-07-21 10:49 GMT+02:00 Gra <graziaz@gmail.com>:
grass.exceptions.CalledModuleError: Module run None ['v.patch', '--o', '-e',
'input=fraf10___________nw,fraf11___________nw,fraf12___________nw,fraf13___________nw,fraf14___________nw,fraf15___________nw,fraf16___________nw,fraf17___________nw,fraf18___________nw,fraf19___________nw,fraf20___________nw,fraf21___________nw,fraf22___________nw,fraf23___________nw,fraf24___________nw',
'output=fraf_patch']
ended with error
output.
could be probably related to [1]. I will try to take a look at it
during GRASS Community Sprint in Como (today).
Martin
[1] https://trac.osgeo.org/grass/ticket/2711
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
