Hello all,
I encountered a few problems while pruning vector boundaries and decided to try to update the algorithm. The biggest problem with the old algorithm was that it didn't work in latlon. From previous mails to to list I got the idea to use the Douglas-Peucker algorithm as implemented in gshhs_dp for pruning lines and boundaries. The algorithm in gshhs was tailored to latlon, but I wanted it to work in any projection and use map units. This is now realized, it works both in latlon and in projections with meters or anything else as map units. The attached prune.c goes to lib/vector/diglib/prune.c The threshold is the deviation of a given point from a straight line connecting the two adjacent points and should be not more than half the map resolution. Using insanely large thresholds can result in duplicate centroids. In my test map with 146000 vertices, 3109 centroids and 4294 areas (areas without centroids are islands, this is wanted), I got 2 duplicate centroids when the threshold was 1000x map resolution, an insane threshold removing over 80% of the vertices. The algorithm itself does not change the first and last point, so there is no more need to pass a boundary without the first and last point to the algorithm. That means that vector/v.clean/prune.c can be modified accordingly.
As before, there is a first routine removing duplicate points. Is there a reason for duplicate points in lines or boundaries? If not, why are they there at all? I converted rasters to vectors extracting areas and typically had above 30% duplicate vertices. Working with large vectors with millions of vertices, they are clogging up the vector. So something for the wish list would be to have line and area vectors without duplicate vertices after map conversions. For the time being, prune should be first run with a threshold of 0.0 as before to remove duplicate centroids. Then lines and boundaries can be pruned beginning with a small threshold and increasing it gently (e.g. next threshold = 2x previous threshold), until the vector is satisfyingly reduced while preserving the desired amount of detail.
So far I tested the new Douglas-Peucker algorithm in different projections and it works fine. But I only tested it on my system (FC6 x86_64, gcc-4.1.1) with grass-6.2.1 and grass-6.3 cvs snapshot from 12.5.2007. If anybody is interested in testing the new algorithm and help make it the new standard for GRASS, please do!
CAUTION: I'm not a programmer, I'm a biologist by training doing GIS and remote sensing work, so I can't guarantee for the code. I tried my best.
Markus (not Neteler but Metz)
(attachments)
prune.c (8.26 KB)
