by testing the manual example of v.rast.stats, I get following error:
v.rast.stats --verbose map=myzipcodes_wake@gbiftest
raster=elevation@PERMANENT column_prefix=elev
method=minimum,maximum,average,stddev,percentile
Adding columns '['elev_minimum DOUBLE PRECISION', 'elev_maximum DOUBLE
PRECISION', 'elev_average DOUBLE PRECISION', 'elev_stddev DOUBLE PRECISION',
'elev_percentile_90 DOUBLE PRECISION']'
Adding column <elev_minimum> to the table
Adding column <elev_maximum> to the table
Adding column <elev_average> to the table
Adding column <elev_stddev> to the table
Adding column <elev_percentile_90> to the table
Processing data (13 categories)...
ERROR: Input window changed while maps are open for read. Map name
<myzipcodes_wake_8088.0>
Updating the database ...
Statistics calculated from raster map <elevation@PERMANENT> and uploaded to
attribute table of vector map <myzipcodes_wake>.
PRECISION', 'elev_percentile_90 DOUBLE PRECISION']'
Adding column
<elev_minimum>
to the table
Adding column
<elev_maximum>
to the table
Adding column
<elev_average>
to the table
Adding column
<elev_stddev>
to the table
Adding column
to the table
uploaded to attribute table of vector map
<myzipcodes_wake>
DEBUG=3 output
<http://osgeo-org.1560.x6.nabble.com/file/n5232313/grass_cmd_output.txt>
i messed up r.univar implementing a new flag. I will fix it in trunk
and implement some tests for v.rast.stats and a zone test for
r.univar.
Best regards
Soeren
2015-10-24 20:28 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
Helmut Kudrnovsky wrote
hi,
Adding column
<elev_minimum>
to the table
Adding column
<elev_maximum>
to the table
Adding column
<elev_average>
to the table
Adding column
<elev_stddev>
to the table
Adding column
to the table
<myzipcodes_wake>
DEBUG=3 output
