The command
v.rast.stats map=SomeVector raster=SomeRaster column='t'
fails. Perhaps the line
<https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast.stats.py#L265> ;
was simply meant to be something like:
for colname in colnames:
variable = colprefix + '_' + colname
print colname
?, Nikos
On Thu, Nov 19, 2015 at 1:28 PM, Nikos Alexandris <nik@nikosalexandris.net>
wrote:
The command
How exactly does it fail?
print colname
?, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Nikos:
> The command
Anna:
v.info -c Test
INTEGER|cat
INTEGER|Id
CHARACTER|Name
v.rast.stats map=Test raster=LT51960282005221KIS00_B1 column='t'
File "/osgeo/grass70/dist.x86_64-unknown-linux-gnu/scripts/v.rast.stats", line 306, in <module>
main()
File "/osgeo/grass70/dist.x86_64-unknown-linux-gnu/scripts/v.rast.stats", line 268, in main
i = variables[variable]
KeyError: 'firsquartile'
Strange, however, it does not fail always!?
Another example
v.info -c test
INTEGER|cat
v.rast.stats map=test raster=test column_prefix='t'
seems to work and gives
DOUBLE PRECISION|t_number
DOUBLE PRECISION|t_minimum
DOUBLE PRECISION|t_maximum
DOUBLE PRECISION|t_range
DOUBLE PRECISION|t_average
DOUBLE PRECISION|t_stddev
DOUBLE PRECISION|t_variance
DOUBLE PRECISION|t_coeff_va
DOUBLE PRECISION|t_sum
DOUBLE PRECISION|t_first_qu
DOUBLE PRECISION|t_median
DOUBLE PRECISION|t_third_qu
DOUBLE PRECISION|t_per90
Nikos
neteler
November 19, 2015, 9:53pm
4
On Thu, Nov 19, 2015 at 8:53 PM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Nikos:
> The command
Anna:
v.info -c Test
INTEGER|cat
INTEGER|Id
CHARACTER|Name
main()
--> typo, should be firs*t*quartile I suppose.
But in my svn copy I don't find that.
Do you have local modifications? In the code I see "first_quartile"
with underscore.
Weird!
Nikos:
>> > The command
Anna:
Nikos:
> v.info -c Test
> INTEGER|cat
> INTEGER|Id
> CHARACTER|Name
> main()
Markus:
Absolutely not.
In the code I see "first_quartile" with underscore.
Weird!
I did not find it either! It's not a typo. It is the result of .replace
(I did some examples).
Nikos
On Thu, Nov 19, 2015 at 2:53 PM, Nikos Alexandris <nik@nikosalexandris.net>
wrote:
Nikos:
> > The command
Anna:
v.info -c Test
INTEGER|cat
INTEGER|Id
CHARACTER|Name
File
306, in <module>
main()
File
268, in main
Another example
v.info -c test
INTEGER|cat
Nikos
Should be fixed in 66864. I still don't understand why it doesn't fail in
the other case though.
Anna
* Anna Petrášová <kratochanna@gmail.com> [2015-11-20 00:10:19 -0500]:
wrote:
> Nikos:
> > > The command
> Anna:
> v.info -c Test
> INTEGER|cat
> INTEGER|Id
> CHARACTER|Name
> File
> 306, in <module>
> main()
> File
> 268, in main
> Another example
> v.info -c test
> INTEGER|cat
> Nikos
Need to look closer -- no time. Yet, why use .replace for adding a prefix?
Nikos
On Fri, Nov 20, 2015 at 4:17 AM, Nikos Alexandris <nik@nikosalexandris.net>
> wrote:
> > Nikos:
> > > > The command
> > Anna:
> > v.info -c Test
> > INTEGER|cat
> > INTEGER|Id
> > CHARACTER|Name
> > File
line
> > 306, in <module>
> > main()
> > File
line
> > 268, in main
> > Another example
> > v.info -c test
> > INTEGER|cat
> > Nikos
At that point is actually removing the prefix. There is a better way to
fix it, but this was quick and easy fix, hopefully effective.
Anna
Nikos
