On 06/10/15 17:51, Martin Landa wrote:
2015-10-06 17:29 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
One can argue that setting them NULL is actually a valid choice as it might
not be legitimate to give them values of pixel so much larger. But maybe
this should be decided by a flag ?
right, a flag could be an option.
Get area and if area < pixel size then
- number = 1
There can be more areas with same category.
Yes, but the 'number' statistic gives you the number of pixels in the area. This number is important to interpret the other statistics (a mean and stddev based on 2 pixels do not necessarily have the same statistical value as the same statistics based on several hundred pixels). Putting number = 1 is a bit of a 'lie', here as there is less than a pixel in the area, but the only way to get any numbers into the statistics is to use the value of a pixel, so number=1 means: we used one single pixel to determine these statistics.
- range = 0
- stddev,variance,coeff_var = 0 (or NULL)
- all other values = pixel value which you can get by replacing the areas by
their centroids, you could use v.what.rast to get the pixel value.
But I wonder if this is not a bit of overkill...
Why? I have request from the users, they are not happy about NULL
values.
But, as already said, one could argue that NULL is the scientifically most correct answer in this case...
v.rast.stats is not about getting pixel values, but about getting statistics of collections of pixel values. When you do not even have one single pixel entirely containted in the area, then it makes sense to say that you cannot calculate any statistics and set the value to NULL.
If you just want pixel values, you can always use v.what.rast based on the area centroids.
I just wonder how to implement within Python script.
Get areas of all polygons (or lenghts of lines) with v.to.db and then divide the features into those with areas above pixel size and those with areas below. Treat each set differently (i.e. the former as before, the latter by using v.what.rast - with the -p flag - to get the pixel value). As the updating of the table is done feature by feature anyhow, all you lose in terms of performance is the additional step of calculating areas/lengths of features.
Probably
rewriting to C would make sense(?)
It might make it more efficient, but I think the python version would work well and the change in python version should not be too complicated.
Moritz
