There is any chance that the v.rast.stats will be paralellized?
Best,
lorenzo
Best,
lorenzo
On 14/06/18 12:24, Lorenzo Bottaccioli wrote:
You mean to treat several rasters at the same time ?
It shouldn't be too complicated to write a wrapper script for this. I would imagine the biggest problem to be the handling of the access to the attribute database file. Not sure that you can have concurrent access to this file by several parallel processes. If this is an issue, we would probably have to add the option to output v.rast.stats results to text files and then load content of these files into at the attribute table of the vector map at the end...
Moritz
Yes, access to attributes would be a challenge / bottleneck for parallelisation, esp. if you have many areas in your vector map. Note that not only SQLite but also DBF is still supported (which puts some limitations)...
Please note also: https://trac.osgeo.org/grass/ticket/3523 for some suggestions for speeding up v.rast.stats (without parallelisation).
Once multiple raster map input is supported, statistics could be computed in parallel for each raster map and then finally uploaded to the attribute table in one single process...
Yet, the region adjustment performed by v.rast.stats would then have to be handled differently from current solution...
I would say it is worth a ticket...
If you want a text file, you could use r.univar directly, no?
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Moritz Lennert
Sent: torsdag 14. juni 2018 13:05
To: Lorenzo Bottaccioli <lorenzo.bottaccioli@gmail.com>; GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] v.rast.stats parallel process
Moritz
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Moritz,
No I mean to process in parallel the stats over many vector entities for example areas. Immagine a large raster with many polygons that want to know the mean or max value in the area.
Ciao,
Lorenzo
2018-06-14 13:20 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no>:
Yes, access to attributes would be a challenge / bottleneck for parallelisation, esp. if you have many areas in your vector map. Note that not only SQLite but also DBF is still supported (which puts some limitations)…
Once multiple raster map input is supported, statistics could be computed in parallel for each raster map and then finally uploaded to the attribute table in one single process…
Yet, the region adjustment performed by v.rast.stats would then have to be handled differently from current solution…I would say it is worth a ticket…
Stefan-----Original Message-----
Subject: Re: [GRASS-dev] v.rast.stats parallel processOn 14/06/18 12:24, Lorenzo Bottaccioli wrote:
It shouldn’t be too complicated to write a wrapper script for this. I would imagine the biggest problem to be the handling of the access to the attribute database file. Not sure that you can have concurrent access to this file by several parallel processes. If this is an issue, we would probably have to add the option to output v.rast.stats results to text files and then load content of these files into at the attribute table of the vector map at the end…
Moritz
On 14/06/18 16:31, Lorenzo Bottaccioli wrote:
Hi Moritz,
Ok. As the module is a scripted fronted to r.univar, the question is more for r.univar then. Parallizing that will probably be a bit more complicated.
Moritz
Ciao,
Lorenzo
2018-06-14 13:20 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no <mailto:Stefan.Blumentrath@nina.no>>:
puts some limitations)...Please note also: https://trac.osgeo.org/grass/ticket/3523
<https://trac.osgeo.org/grass/ticket/3523> for some suggestions for
to be handled differently from current solution...I would say it is worth a ticket...
<mailto:grass-dev-bounces@lists.osgeo.org>> On Behalf Of Moritz Lennert
<mailto:lorenzo.bottaccioli@gmail.com>>; GRASS developers list
<grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>>
> Hi all,
> There is any chance that the v.rast.stats will be paralellized?You mean to treat several rasters at the same time ?
files into at the attribute table of the vector map at the end...Moritz
<https://lists.osgeo.org/mailman/listinfo/grass-dev>
