[GRASS-dev] v.rast.stats with multiple input
Dear GRASS-devs,
I would like to extract statistics for vector geometries from a couple of maps derived from the same terrain model.
Unfortunately, v.rast.stats has two limitations for my use-case:
  1. the rasterization has a significant overhead when called several times
  2. only one percentile column can be produced (while I would like to get both 10 and 90% percentiles)
In order make v.rast.stats more efficient for use cases like mine, I would like to propose the following changes I could imagine:
  1. add an optional input option for a raster map representing the category values of the vector map
  2. make column_prefix and raster option multiple
  3. add additional columns for additional percentiles
Since v.rast.stats is a Python script I could try to come up with a solution, if you generally agree that the proposed changes make sense and are not problematic…
What do you think?
Stefan
