Hello All - I have a question about the v.rast.stats script. I want to maintain a MASK for the process in order to isolate portions of the raster and attaching those stats to the vector table. In the script, any user defined mask is temporarily renamed, but I don’t see a place in the script where a mask is created - by the script - for use in the stats operation. So, can I just take out the mask renaming portion of the script? Thanks,
Chris
On 28/07/08 19:50, chris carleton wrote:
Hello All - I have a question about the v.rast.stats script. I want to maintain a MASK for the process in order to isolate portions of the raster and attaching those stats to the vector table. In the script, any user defined mask is temporarily renamed, but I don't see a place in the script where a mask is created - by the script - for use in the stats operation. So, can I just take out the mask renaming portion of the script?
AFAICT, it depends on whether you want to use the mask also on the cover vector map. If yes, then just remove that part, if not, then move it to just before the line saying "#loop over cats and calculate statistics:" (line 274).
Moritz
