In v.report r30407, lines 153 and 162, the UNITSPARAM variable became quoted. This makes the script print empty output when no explicit unit is specified, because v.to.db syntax becomes internaly eg.:
and the empty single quotes in the end of the string results in an
error:
Sorry <> is not a valid option
Anybody minds if I strip the problematic double quotes off?
ah, sorry about that, fixed in r30864 and r30865 (went ahead and did it
myself as it was my fault & it had been backported with another fix).
thanks for spotting it.
Hamish
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. http://tc.deals.yahoo.com/tc/blockbuster/text5.com
