[GRASS-dev] v.surf.bspline density and distance estimates
Hi devs, can anybody tell how v.surf.bspline computes the point density and mean distance. And what is the unit, pixels, as also used for length spline steps or meters?
On Fri, Jun 16, 2017 at 11:28 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
point density is the number of points divided by the size of the bounding box of the points
mean distance is the square root of the size of the bounding box divided by the number of points
the unit is map unit, you can then figure out a reasonable resolution (in map units) for the current region
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Thanks!
I was trying to find out from the source code, but not understanding C I couldn’t find where this was described / done.
Markus M
I think it would be good to add your explanation to the manual page. I was trying to come up with a text, but then I realized there is still some ambiguity left. According to the manual page, the ns_step and ew_step parameters are in pixels (which I would interpret as ‘number of pixels’). However, the example of ‘Basic interpolation and raster output with a longer spline step’ in the manual page talks about mapping units. So if the region’s resolution is 100 meter, is the ns_step and ew_step 2500 meter (25 pixels) or 25 meters? The former would be more conform common practice in grass I think.
v.surf.bspline input=point_vector raster=interpolate_surface ew_step=25 ns_step=25
A bilinear spline interpolation will be done with a spline step length of 25 map units.
Markus M
On Sat, Jun 24, 2017 at 11:23 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
The unit of ns_step and ew_step is map units, but that does not really make sense, the unit of the spline steps should rather be pixels. However, the unit of the spline step options can not be changed because it would break compatibility.
Markus M
In the manual page, in the first paragraph of the Notes, may I suggest to change the text: The length (in mapping units) of each spline step is defined by for the east-west direction and for the north-south direction.
The length of each spline step is defined by ew_step for the east-west direction and ns_step for the north-south direction. Step is defined in number of pixels.
to something along the lines:
ew_step****ns_step
Markus M
On Mon, Jul 24, 2017 at 6:30 PM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
The length (in mapping units) of each spline step is defined by ew_step for the east-west direction and ns_step for the north-south direction.
Done in trunk r71312 for all affected lidar modules.
Markus M
