On 27/11/08 09:36, Markus Neteler wrote:
On Thu, Nov 27, 2008 at 12:10 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
On 26/11/08 11:34, Markus Neteler wrote:
I try to use v.db.addtable with a second layer but v.to.db apparently
fails
(called by v.db.addtable):
# Spearfish
g.copy vect=roads,myroads --o
v.info -c myroads
v.db.addtable myroads table=extratab layer=2 columns="cat
integer,label varchar(100)"
Updating database...
100%
1 categories read from map <- BAD should be 6
Why, roads has no features in layer two, so just by copying it and adding a
new table to another layer, you do not add new categories in that layer. You
would need 'v.category option=add layer=2' for that.
Well, I though v.db.addtable would take care of doing the v.category job for
me (see script).
AFAIKS, it doesn't. I'm not sure I think that this would be a good idea, either, as it would indiscriminately attribute categories to all features in the map (e.g. boundaries and centroids, not only centroids), unless you add a type option.
I have the feeling that this would only complicate issues as too much would happen without the user really knowing, so I have a preference for leaving it to the responsibility of the user to create category values.
Probably the docs could be better about all this, though.
v.db.select myroads layer=2
cat|label
<- empty, should have 6 cats
# compare layer1:
v.db.select myroads layer=1
cat|label
0|no data
1|interstate
2|primary highway, hard surface
3|secondary highway, hard surface
4|light-duty road, improved surface
5|unimproved road
# calling directly v.to.db
v.to.db myroads layer=2 option=cat col=cat qlayer=1
Shouldn't this be:
v.to.db myroads layer=2 option=query col=cat qlayer=1 qcolumn=cat
And to respond to Peter's original query, i.e:
I have a vector layer FOO which is linked to two tables in layers 1 and 2.
The categories for each vector element are different in layer 1 and (e.g. a certain area may have the cat value "51" in layer 1 and a cat value of "42" in layer 2).
Let's assume that layer one has a VARCHAR column containing the names of the region (e.g. database_layer_1: 51,"Wolfenstein" database_layer_2: 42 )
If a new VARCHAR column is added to layer 2 by v.db.adcol,
how can the the names from layer 1 be copied into it?
it should actually be (assuming that the varchar attribute in layer 1 is called 'name':
v.db.addcol FOO layer=2 col='name varchar(Size)'
v.to.db myroads layer=2 option=query col=name qlayer=1 qcolumn=name
Moritz
