Hi devs,
I have hundreds of vector maps corresponding to a time series of burned areas in the state of Victoria, Australia. To be able to extract the number of classes (diversity) and the most common LC/slope burned (mode), I need to transform each polygon vector map to raster, then use r.statistics, then use r.mapcalc “LC_mode = @bushfire_20000103_LC_mode” and then v.rast.stats (could use v.rast.stats directly if it had mode and diversity) to get the values.
In any case, my problem arises when polygons do not overlap the center of the cell and therefore I get null rasters out of v.to.rast [1]. Consequently I cannot get info of LC and slope classes for those polygons.
Is there a way to avoid this behavior in v.to.rast and be able to get info for those polygons too? How can I get a list of all the polygons that do not overlap the center of the grid cells to then use a different approach for those ( if they are not too many :-/ )?
What would you recommend?
Thanks a lot in advance!
Vero
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-October/076676.html
