Glynn Clements wrote:
> I have seen this message in the GDAL list:
> On Tue, Nov 28, 2006 at 11:03:00AM +1100, Craig Feuerherdt wrote:
> > I am using Gentoo Linux.
> > When I attempt to use ogrinfo I get the following errors:
> > ogrinfo PGeo:b_pgeo
> > ERROR 1: /usr/grass-6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> > ERROR 1: /usr/grass- 6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> > Segmentation fault
> > I can not work out why the error involves GRASS?
> cd lib/vask/
> grep stdscr *
> V_call.c: getyx (stdscr, y, x);
> V_exit.c: keypad(stdscr, 0);
> V_init.c: keypad(stdscr, 1);
> V_support.c: getyx(stdscr, cury, curx) ;
Note that most of the curses "functions" which don't begin with "w"
are actually macros which call the corresponding function with
"stdscr" as the target window, e.g.:
#define addch(ch) waddch(stdscr,ch)
#define addchnstr(str,n) waddchnstr(stdscr,str,n)
#define addchstr(str) waddchstr(stdscr,str)
... and so on.
My guess is that, in some curses implementations, stdscr might be a
macro. A normal GRASS binary distribution wouldn't be compatible with
such an implementation; you would need to re-compile GRASS.
Having thought about this some more, I'm more interested in how GDAL
ends up using the parts of GRASS which use the vask library.
I should have guessed; it's the imagery library:
/* Check if this is a valid GRASS imagery group. */
else {
struct Ref ref;
I_init_group_ref( &ref );
if ( I_get_group_ref( pszName, &ref ) == 0 ) {
free(pszGisdb); free(pszLoc); free(pszMapset); free(pszElem); free(pszName);
return NULL;
for( int iRef = 0; iRef < ref.nfiles; iRef++ )
papszCells = CSLAddString( papszCells, ref.file[iRef].name );
papszMapsets = CSLAddString( papszMapsets, ref.file[iRef].mapset );
G_add_mapset_to_search_path ( ref.file[iRef].mapset );
I_free_group_ref( &ref );
Now, none of this involves vask, but because some parts of the imagery
library require it, the imagery library itself requires it.
AFAICT, the following files from lib/imagery actually use vask:
file used by
ask_bands.c <nothing>
ask_colors.c <nothing>
tape_info.c <nothing>
v_exec.c ask_bands.c, tape_info.c (both unused)
vask_group.c i.class
IOW, the only reason why the imagery library needs to use vask is
because i.class uses I_vask_subgroup_old(). In which case, that code
can be moved to i.class, leaving the vask and edit libraries as the
only libraries which uses curses.
More later ...
