[GRASS-dev] vdigit issues in VNC session
Hi
Using vdigit in VNC session I can't get snapping tool to work. Right
mouse key works the same as middle, i.e. cancels.
With same data in the same usage scenario in local session the right
mouse key behaves fine.
Why the difference?
Maciek
Maciej Sieczka
www.sieczka.org
Maciej Sieczka pisze:
Hi
Using vdigit in VNC session I can't get snapping tool to work. Right mouse key works the same as middle, i.e. cancels.
With same data in the same usage scenario in local session the right mouse key behaves fine.
Why the difference?
Specs: grass64 SVN r33523, Debian testing amd64 (both VNC server and
client), VNC 4.1.1 +X4.3.0.
Maciek
Maciej Sieczka
www.sieczka.org
Why the difference?
Specs: grass64 SVN r33523, Debian testing amd64 (both VNC server and client), VNC 4.1.1 +X4.3.0.
Hi All
I have been checking from time to time in my subsequent GRASS 6.4 builds
for this issue. Good news! Some change introduced after r34915
(2008-12-16) up to r35308 (2009-01-10) fixed the problem.
That's great because I can know finally record the vdigit screencasts
(with vnc2swf) I long time ago promised to someone. Thanks!
Maciek
Maciej Sieczka
www.sieczka.org
