[GRASS-dev] vdigit working on Mac mostly
Also, I now have vdigit working in wxPython sort of.
There used to be a combo box on the left of the digitizer tool bar that allowed selection of the map to digitize (or to create a new map). This has disappeared. Has it been removed or is it just not showing up? There was an earlier problem with combo boxes in Mac toolbars. I thought it was fixed, but maybe it’s back. There is a workaround (used for the combo box in the main display toolbar).
I was able to make some changes to a test map, but it locked up when I tried to move an object.
I’ll keep experimenting now that this is working.
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
2008/10/9 Michael Barton <michael.barton@asu.edu>:
but maybe it's back. There is a workaround (used for the combo box in the
no, the combobox in vdigit toolbar hasn't been removed. Seems to be a
bug in Mac wxPython. Can you see combobox in map toolbar?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On Oct 8, 2008, at 11:08 PM, Martin Landa wrote:
I went ahead and applied the Mac fix for the missing combo box to develbranch_6. Could you check to see if it works OK for you? Thanks.
Back to work.
Michael
Seems to work here (backpored to trunk).
Martin
