[GRASS-dev] Vect_build() & verbosity
I would like to make V_build() fn verbose sensitive, i.e. to print
information about building topology only on the standard or higher
verbosity level. E.g. in lib/vector/Vlib/build.c:int printmsg()
if ( Msgout != NULL && G_verbose() >= G_verbose_std()) {
There is related issue, some of modules print V_build() output to
stdout (33) and some to stderr (40). I think all modules (except of
v.build) should send V_build() output information to stderr.
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
you are talking about changing the vector lib API, which is a much bigger
deal than just tweaking progress messages.
\fn int Vect_build ( struct Map_info *Map, FILE *msgout )
\brief build topology for vector map
\return 1 on success, 0 on error
\param Map_info structure, file for message output (stdout/stderr for example) or NULL
We need to know why that was chosen before we change it to:
int Vect_build ( struct Map_info *Map )
A solution in Vect_build() where verbosity is only used if msgout=stderr
is ugly; adding verbosity control to stdout log messages is most likely
a bug.
FWIW, I too would like to see Vect_built() observe the verbosity controls,
using --quiet should work. But I also think it is often very helpful to see
that output, if all build features are count=0, you know very quickly that
you made a mistake.
Martin Landa wrote:
just to summarize, I suggest to reduce verbosity levels to three levels:
--q 0 MIN_LEVEL (only warnings + fatal_errors)
     1 STD_LEVEL (progress information)
--v 2 MAX_LEVEL (any "useful" information, another points is what is "useful")
E.g. Vect_build () output:
0 ... nothing printed
1 ... Registering lines: ... , etc.
2 ... all current info
Three level are enough I think, then we should move selected messages
to G_debug (1, ).
Any objections (in case I missed something)?
Yes, I prefer to keep an option open between normal and silent.
e.g. my recent (but very short lived) modification of g.rename,
verbosity: --quiet is completely quiet.
           GRASS_VERBOSE=1 shows only map names.
           normal and --verbose show map names and elements.
It is nice to have that control if we want it, and it doesn't hurt any.
I think Radim had the right approach with G_debug(), standard debug levels
at 1,3,5. It leaves space for expansion. So I'd prefer we used 1,3,5 for
message levels instead of 0,1,2. They symmetry with G_debug() is nice too.
Glynn:
On a related note, I would appreciate some way to disable percentage
output separately from other messages. My usual terminal (XEmacs'
shell-mode) doesn't support ^H, so the G_percent() output is garbage.
We could expand on GRASS_MESSAGE_FORMAT=gui and add
GRASS_MESSAGE_FORMAT=flat which would just print "Done.\n"
(or nothing if used with --quiet) for use with G_percent() and G_clicker().
Jáchym Èepický wrote:
--verbose is here to set temporary GRASS_VERBOSE to heigher level, if
it is set to 0 or 1
so it makes sence to have it, but Im not sure, if it makes sence to
have it in the help message na all the manual pages..
Me neither (help pages and command line --help output). We already have
silent parser flags (--html-description,...). Maybe just mention to use
it in the help page of the few modules that do use a verbose mode?
shrug.
Hamish
