trying the new Python-Vector API, I found a discrepancy which
I would like to understand:
On 'roads' in Spearfish, v.info reports
Number of lines: 825
based on Vect_get_num_primitives(&Map, GV_LINE)
If I use in the Python API the Vect_get_num_lines(map),
I get
Number of lines: 2876
Difference:
- Vect_get_num_primitives uses map->plus.n_llines
- Vect_get_num_lines uses map->plus.n_lines
Which one is right? Probably Vect_get_num_lines() should
use n_lines as well and we need an extra function to
report segments?
On 9/25/06, Markus Neteler <neteler@itc.it> wrote:
I get
Difference:
report segments?
It must be a bug in Python API, Vect_get_num_lines() must
also give 825.
Radim
grass-dev mailing list
grass-dev@grass.itc.it
I get
Difference:
report segments?
also give 825.
When working on a revision of d.vect.chart, I got the feeling that
Vect_get_num_lines was used as if it returned the number of _all_ the
features in the map, not only the lines (from lines 49+ of
display/d.vect.chart/plot.c):
nlines = Vect_get_num_lines ( Map );
/* loop through each vector feature */
for ( line = 1; line <= nlines; line++ ) {
G_debug ( 3, "line = %d", line );
ltype = Vect_read_line (Map, Points, Cats, line);
As you can create charts with vector point, I don't know how this would
work, if Vect_get_num_lines returns only number of lines.
Moritz
Hello Moritz
My understanding is that a point is represented as a line containing only one node. So the number of lines is equivalent to the number of points. I have very limited experience with this but in any maps I came across while testing recent changes to v.surf.idw to remove it's dependency on topology, this is how points where represented.
Paul
Paul Kelly wrote:
Hello Moritz
Thanks Paul, that explains it, and probably also Markus' issue, no ?
A related question: I use Vect_cidx_find_next() which returns an 'id' value which corresponds to:
id = ci->cat[cat_index][2]
ci being a Cat_index structure in which cat is defined as:
int (*cat)[3]; /* array of cats (cat,type, lines/area) */
is the 'lines/areas' equivalent to the line number used in the above Vect_read_line() call. It seems to be (at least it seems to work when I use it), but I just want to make sure.
Moritz
>Hi,
>I get
>Difference:
>report segments?
also give 825.
While a bug in Python API is likely, I wonder about the
difference between
map->plus.n_llines and
map->plus.n_lines
May I ask you to explain it (or point me to the docs?)?
Related: I assume that v.info should be changed to use
Vect_get_num_lines() etc instead of Vect_get_num_primitives()?
thanks
> >Hi,
> >I get
> >Difference:
> >report segments?
> also give 825.
difference between
map->plus.n_lines
n_lines are all primitives (elements) in coor file, i.e. without
areas and n_llines are only primitives of type GV_LINE.
It depends what you want to print, IMO it is correct.
Radim
thanks
