I was going to use Vect_line_buffer function but was unable to
understand it's tolerance parameter. Could somebody extend a bit
documentation to make it more clean what does it mean.
For my module I need to create buffer around line without any "round
caps" at line end -> buffer must look like square and not extend
beyond input line end. Ideas how to tweak tolerance setting to get
such functionality out of Vect_line_buffer?
extend a bit documentation to make it more clean what does it mean.
I am not 100% sure,
to get such functionality out of Vect_line_buffer?
maybe 'v.parallel distance=' for both left and right side of line?
Unfortunately this is a quite big problem for GRASS if nobody from
-dev ML can not explain how GRASS internal stuff works
I hope You, Росен, will spend some time to add comments and examples
to existing vector lib functions to make them more non-ūbercoder
friendly.
On Spearfish example that I used to test my initial version of my
module I managed to get "flat" buffer ends instead of "round caps" by
setting tolerance to 1000. Still I have no idea why it works and how
large should tolerance value bee for other buffer sizes/locations. I
will take a look on Vect_line_parallel solution as it will be not so
hackish.
Thanks for hints!
Maris.
2008/5/18 Hamish <hamish_b@yahoo.com>:
Maris:
I am not 100% sure,
from -dev ML can not explain how GRASS internal stuff works
It's not so bad, Radim did leave notes. e.g. in lib/vector/Vlib/buffer.c in the case of public functions they are even Doxygen-ized so they appear in the programmer's manual. For me "grep" does the job.
\brief Create parrallel line
\param InPoints input line
\param distance create parrallel line in distance
\param tolerance maximum distance between theoretical arc and polygon segments
\param rm_end remove end points falling into distance
\param[out] OutPoints output line
