Huidae had added the nice feature in v.in.dxf (now functional, I guess)
that a broken vector map is immediately removed when import wasn't
successful and is not left behind.
This is an issue which affects various modules. I think we should
add this somehow to the vector library since broken vector maps
aren't really useful. The tmp file approach of raster maps is
more failsafe here. Since tmp doesn't exist for vector maps,
any ideas how to implement that?
At least v.in.ascii needs it, maybe also v.in.ogr.
On Mon, Jul 03, 2006 at 02:35:32AM +0200, grass@intevation.de wrote:
Index: main.c
RCS file: /grassrepository/grass6/vector/v.in.dxf/main.c,v
retrieving revision 1.35
retrieving revision 1.36
diff -u -d -r1.35 -r1.36
--- main.c 12 Jun 2006 05:42:40 -0000 1.35
+++ main.c 3 Jul 2006 00:35:30 -0000 1.36
@@ -179,6 +179,8 @@
else {
+ G_warning(_
+ ("Failed to import DXF file! The created vector file will be deleted."));
fprintf(stderr, "REMOVE [%s]\n", output);
Vect_delete(output);
Is there any way to know from the library if a map has not been completely
imported? IMHO, incomplete import is different from corrupted files (well
sometimes it could mean broken vectors), so only modules importing files can
determine to remove incomplete vectors.
Huidae Cho
On Mon, Jul 03, 2006 at 08:46:22AM +0200, Markus Neteler wrote:
SQL transactions, on back-ends which support them.
OK.
I have added a couple of Vect_delete() calls to v.in.ascii before
G_fatal_error() happens. Like this cruft is removed before the
error message appears.
Huidae Cho
> Hi,
> Markus
> > Index: main.c
> > @@ -179,6 +179,8 @@
> > else {
> > + G_warning(_
> grass-dev mailing list
> grass-dev@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
