[GRASS-dev] vector display clipping
can anyone explain the difference between grass64 and 7 in clipping vector data for display? I attached 2 pictures created with d.mon png and cairo driver (to avoid influences from GUI) and you can see that in 64 the lines are clipped to match computational region while in grass7 it seems to display all vector features which have at least part in the region. Is this bug or feature? I couldn’t find any discussion on this topic…
Anna
(attachments)
driver
Which is png and which is cairo?
bug or feature? I couldn't find any discussion on this topic...
In 7.0, there are two distinct sets of clipping operations.
D_set_clip_mode, D_set_clip and D_clip_to_map control clipping which
is performed within the display library. The default is no clipping.
Using this functionality for graphical clipping is problematic if you
use thick lines, as clipped lines will be capped at the point where
they're clipped. It would also affect the dash offset for dashed lines
(although that isn't implemented yet).
Additionally, the driver's Set_window function establishes a clip
region (e.g. via cairo_clip() for the cairo driver). This defaults to
the entire "screen", but can be overridden by setting the environment
variable GRASS_FRAME.
Arguably, the code which sets up the coordinate system so that the
current region just fits the display (D_setup) should also set the
clip region to fit the current region.
However, this is complicated slightly be the fact that there's no
distinction between the display "frame" (either the screen or the
frame set by GRASS_FRAME) and the current clip region, so setting a
clip region would lose the only record of the frame.
thanks for reply,
On Tue, Sep 16, 2014 at 7:59 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
driver
the map70.png is cairo, the other one is png.
they’re clipped. It would also affect the dash offset for dashed lines
(although that isn’t implemented yet).
Is there any way to set different default mode without modifying the code?
Additionally, the driver’s Set_window function establishes a clip
the entire “screen”, but can be overridden by setting the environment
However, this is complicated slightly be the fact that there’s no
distinction between the display “frame” (either the screen or the
I still don’t understand if the current behavior in 7 is intended and if so, why no vector clipping is better?
Anna
No.
I still don't understand if the current behavior in 7 is intended and if
It isn't intended, it's an oversight.
On Wed, Sep 17, 2014 at 4:18 PM, Glynn Clements <glynn@gclements.plus.com>
code?
No.
I see. So, are you (or anyone else who understands this part of code) going
to do something about it?
Try r62026.
This sets the clip region to the destination rectangle by default.
However, there may be situations where this clips things which
shouldn't be clipped. E.g. if you're plotting points with
"d.vect ... icon=...", points near the edge of the map will probably
have their icons clipped to the bounds of the map.
On Wed, Sep 17, 2014 at 6:56 PM, Glynn Clements <glynn@gclements.plus.com>
and if
going
Try r62026.
thanks a lot!
yes, but that's fine (at least for me)
but, d.rast freezes when I try to zoom to a map with png driver. With cairo
driver, everything works fine.
Anna
On Wed, Sep 17, 2014 at 9:40 PM, Anna Petrášová <kratochanna@gmail.com>
For me too. I was thinking about it and the behavior is not what I expect
but it is actually what I want at the end. So it seems to me perfectly
fine. Thanks a lot, Glynn.
and if
going
Try r62026.
thanks a lot!
cairo driver, everything works fine.
Steps to reproduce (nc_spm_08):
export GRASS_RENDER_IMMEDIATE=png
g.region rast=elevation
export GRASS_WIDTH=100
export GRASS_HEIGHT=501
d.rast elevation
99%
The problem is here:
http://trac.osgeo.org/grass/browser/grass/trunk/lib/display/raster.c#L169
    return (A_row < src[1][1]) ? A_row : -1;
-1 is never selected because src is always greater than A_row
Anna
This should be fixed by r62036.
