I just found and fixed a cryptic bug when importing vector data with polygons. This bug is most often the reason for warnings like
WARNING: Number of incorrect boundaries: X
during vector import. If such warnings appear, the result is corrupt. The bug was not in the code itself, but was caused by compiler optimization of the code. The relevant code has been rewritten accordingly in GRASS 7.2, 7.4, and 7.5.
If possible, please update your GRASS version to the latest svn version of GRASS 7.2, 7.4, or 7.5.
Markus M
