After r37270 I get a compile error in trunk/lib/vector/diglib
The portability test in diglib is no longer passed, probably because
portable.c and port_init.c have been modified. According to the
changeset it (the compile error) doesn't make sense, but I observed that
too when I put in LFS support. The files test32.ok and test64.ok must be
created anew, preferably after some testing.
Anybody else getting this compile error?
Best,
Markus M
2009/5/21 Markus GRASS <markus.metz.giswork@googlemail.com>:
not me on 32bit, LFS enabled. Hm, probably the changes should be reverted(??)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin Landa wrote:
No need to revert IMHO, the changes do not look serious, it was just
documentation and adding const where necessary when I had a look at the
changeset.
BTW, I got the compile error on Linux 64bit, LFS enabled, after make
distclean. test.c may need a close look, then test32.ok and test64.ok
need to be created anew and tested on different systems, with and
without LFS (that's what I did before submitting LFS to the vector
libs). Unfortunately I have currently neither the resources nor the time
to do some testing on my side. I can't really judge how important that
portability test is, a good reason to make sure it is passed?
Markus M
found it and fixed it in r37344. Looks like I was the culprit
Markus M
Martin Landa wrote:
Martin
