[GRASS-dev] view trac tickets disabled?
now and then I want to view existing GRASS trac tickets, but going to https://trac.osgeo.org/grass and clicking on “View Tickets” leads me to https://github.com/OSGeo/grass/issues. Can this redirection be reverted, please? I need to be able to search GRASS trac tickets.
Markus M
Hi Markus,
On Fri, Feb 7, 2020 at 3:40 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
The links in in the Bug Tracking section work:
https://trac.osgeo.org/grass#BugTracking
The section provides context, so it should be clear that person is opening a list of old issues. There is no “all tickets” link though - it is just whatever it was before.
Vaclav
On Fri, Feb 7, 2020 at 10:06 PM Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Markus,
What is the reason why going to https://trac.osgeo.org/grass and clicking on “View Tickets” is leading me to https://github.com/OSGeo/grass/issues?
Markus M
Hi Markus,
Markus Metz <markus.metz.giswork@gmail.com> schrieb am Fr., 7. Feb. 2020, 22:22:
They should be actually two buttons.
One for GH and one named “Old tickets” which I had set up as well for obvious reasons. Unfortunately the latter is at time only visible when logged in to trac.
I have no clue why.
Will check if this can be changed to always visible.
markusN
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
What is the reason why going to https://trac.osgeo.org/grass and clicking on "View Tickets"
One for GH and one named "Old tickets" which I had set up as well for obvious reasons.
I have no clue why.
I just checked:
trac admin settings tell me: "The permission TICKET_VIEW was already
granted to anonymous. "
Any other ideas? It is all defined in "trac.ini".
markusN
Hi again,
The problem of the missing button seems to be solved (by actually
re-running the permission assignment in the trac admin section after
having edited trac.ini).
Now there are two buttons at https://trac.osgeo.org/grass
- "View Tickets" --> pointing to GitHub issues
(https://github.com/OSGeo/grass/issues)
- "Old tickets" --> pointing to the old ones in trac.
HTH,
Hi Markus,
On Sat, Feb 8, 2020 at 11:21 AM Markus Neteler <neteler@osgeo.org> wrote:
Hi again,
Perfect, works for me, thanks!
Markus M
