Dear all,
I am struggling to understand how to delete an object, including its
attached attributes, from a GRASS vector map.
I open the map with:
Vect_open_update ( &Map, MAPS[i].tempname, mapset );
Then I find the category IDs of the objects I want to delete and then I
do:
Vect_delete_line ( &Map, cat );
Vect_field_cat_del ( Cats, field, cat );
and Vect_close() after the work is done.
However, the next module I try to run on the modified map
throws an error:
ERROR: Attempt to read dead line [282]
How do I eliminate dead lines from the map?
Ben
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeology Ltd
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke@oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
On Thu, Aug 21, 2008 at 6:54 PM, Benjamin Ducke
<benjamin.ducke@oxfordarch.co.uk> wrote:
Dear all,
do:
throws an error:
In vector/v.digit/line.c I have found:
/* delete lines with less than two points */
Vect_delete_line(&Map, el->line);
for (i = 0; i < el->Cats->n_cats; i++) {
check_record(el->Cats->field[i], el->Cats->cat[i]);
Might be something like this...
2008/8/23 Markus Neteler <neteler@osgeo.org>:
do:
the second argument of Vect_delete_line() is feature id not category.
Feature ids start at 1. You get number of features by
Vect_get_num_lines().
Good luck, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
2008/8/23 Martin Landa <landa.martin@gmail.com>:
do:
I forgot to mention, to get list of feature ids which have given
field/category use
Vect_cidx_find_all(..., cat, list);
then
for (i = 0; i < list->n_values; i++) {
Vect_delete_line(&Map, list->value[i];
Note that you need to open vector map at topology level (2) to use
Vect_cidx_find_all(..., cat, list) otherwise you need to read all
features and check their category manually.
