[GRASS-dev] want to color vector map. What am I doing wrong?
I want to color a vector map. I’m just trying it with some test maps from the North Carolina demo set. I used the ‘manage color rules interactively’ dialog in the GUI and am using a version of GRASS 7 compiled on 1 November.
Is there no way to use a character column for colors?
Even when I use a numeric column (e.g., the column “pumpers” in the firestations vector points map), the OK, apply, and preview buttons remain greyed out after I have filled out the table with values and colors. I’ve tried each of the integer values in the column and using the min and max values only. Yes, each of the table lines is checked.
I thought that maybe this only works for area maps. But I have the same problems with them. (I tried the geology map).
Clicking the “add column” button does nothing AFAICT
I also tried the v.colors approach. I was able to do everything (no greyed out buttons). But no colors either.
So what am I doing wrong? Making colored thematic maps is a pretty basic and important function. I didn’t try the thematic map layer because I wanted to do points too and it only does areas.
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
Hi Michael,
On Tue, Dec 3, 2013 at 4:12 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
I think it’s currently somehow broken due to some other changes in GUI which were not reflected in this dialog. I will try to fix it, probably in the next weeks. I will actually need this functionality, too.
I think it requires numbers but I am not sure if it is the problem of GUI or underlying module (the latter I guess).
Anna
Michael
C. Michael Barton
USA
grass-user mailing list
grass-user@lists.osgeo.org
Thanks for the quick reply. Too bad it’s broken but glad it’s not me being very dense.
Michael
Anna
Michael
C. Michael Barton
USA
Hi Michael and Anna,
I am sorry this bug was introduced by me. Please try r58390.
Best,
Stepan
---------- Původní zpráva ----------
Od: Michael Barton Michael.Barton@asu.edu
Datum: 3. 12. 2013
Předmět: Re: [GRASS-user] want to color vector map. What am I doing wrong?
Michael
C. Michael Barton
USA
On Dec 3, 2013, at 2:25 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Hi Michael,
Anna
Michael
C. Michael Barton
USA
