Hi, I think this has been mentioned before, but can't find the email.
When running some functions or addons, e.g., r.forestfrag, I get the
warning:
"WARNING: No data base element files found"
This seems to happen in some mapsets only. What is this warning about,
and how to avoid it / remove it?
In my experience it comes from a g.remove call that tries to remove a file that doesn't exist. So generally, testing for its existence before removing avoids the warning.
warning:
I see, in my script I remove temporary layers using g.remove, but I am also using the procedure with atexit.register(cleanup)), which will (attempt to) clean up the layers at the end of the script.
On Mon, Mar 21, 2016 at 11:41 AM, Moritz Lennert
avoids the warning.
Also i.colors.enhance suffers from that.
Do we have any "best practice" example for that in an existing core script?
avoids the warning.
Would be good to have a 'best practice' example. I have used before something like:
rast = 'my_raster'
cf = grass.find_file(name=rast, element = 'cell', mapset=grass.gisenv()['MAPSET'])
if not cf['fullname'] == '':
grass.run_command("g.remove", type="raster", name=rast, quiet=True)
But I guess there are better ways to do this?
P.s. in the find_file example above, is it sufficient to use as 'element' 'cell', i.e., does that also find fcell and cellhd layers?
On Tue, Mar 22, 2016 at 7:22 AM, Paulo van Breugel
file
removing
avoids the warning.
script?
something like:
rast = 'my_raster'
Best practice is just to not remove layers which don't exist. So don't
remove the temporary maps inside the script, but rather inside the
registered cleanup procedure which is called every time. The temporary
maps should be added to a global list as they are used, so when you
interrupt the script in the middle only the already created temporary
maps will be deleted.
All of 'raster', 'rast', 'cell' will find raster maps (of all
types),not sure what do you mean with cellhd layer.
file
removing
avoids the warning.
script?
something like:
rast = 'my_raster'
That is what I am doing now, using atexit.register(). But if a script generates a very large number of layers, it might be worthwhile removing them in between to save disk space (I recently had to such a case at hand, where keeping the intermediate layers would have taken up too much space). But generally yes, following the cleanup procedure makes absolutely more sense. In the script I referred to in the initial email, I used both because at the time of writing the script, I misunderstood the working of atexit.register().
I was looking at the possible element types for the find_file function at https://grass.osgeo.org/programming7/find__file_8c.html, and cellhd was mentioned as one possible element type (I couldn't find a list though of all possible database elements)
On Tue, Mar 22, 2016 at 3:02 PM, Paulo van Breugel
Do you mean
g.findfile -l
List of available elements:
raster (raster map(s))
raster_3d (3D raster map(s))
vector (vector map(s))
label (paint label file(s))
region (region definition(s))
group (imagery group(s))
