Starting a session I get:
WARNING: No metadata file available
Can this be including a small hint to fix it.
Yann
Yann
YannI don't know what is the reason for the message. How is your grass7
directory? Other circumstances? See the source code here:
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/g.extension/g.extension.py#L195
Vaclav
PS: Which system/terminal emulator is preserving colors when copy pasting
from command line? (so I can avoid it
grass-dev mailing list
grass-dev@lists.osgeo.org
it is a new compile of svn on Mac, opening a mapset that is few months old. I am compiling the add-ons too in it.
Yeah i am struggling with that too… That is the “added benefits” of Mac.
Yann
I don’t know what is the reason for the message. How is your grass7 directory? Other circumstances? See the source code here:
Vaclav
PS: Which system/terminal emulator is preserving colors when copy pasting from command line? (so I can avoid it
YannI don’t know what is the reason for the message. How is your grass7 directory? Other circumstances? See the source code here:
Please try:
$ ls .grass7/
addons rc r.li toolboxes
$ ls .grass7/addons/
bin docs etc modules.xml scripts
ls …/.grass7/
rc toolboxes
I compile add-ons directly in the tree.
Please try:
$ ls .grass7/
bin docs etc modules.xml scriptshttps://trac.osgeo.org/grass/browser/grass/trunk/scripts/g.extension/g.extension.py#L195
2015-02-22 5:22 GMT+01:00 Yann Chemin <ychemin@gmail.com>:
ls ../.grass7/
rc toolboxesI compile add-ons directly in the tree.
addons metadata file is created by g.extension. So in your case it's
missing. It's not so big problem, just when removing addon you will
need to do it manually. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Feb 22, 2015 9:35 AM, “Martin Landa” <landa.martin@gmail.com> wrote:
ls …/.grass7/
addons metadata file is created by g.extension. So in your case it’s
missing.
Should the message be changed to indicate which file is missing? Or, at least, mention ‘addons’?
2015-02-22 10:33 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
least, mention 'addons'?
'addons' mentioned in r64721. Martin
Martin Landa
