but I failed...
So what do I have to do? I can checkout/download the tree for r.streams via versions to any local folder. Should I then run the make command? what should that make command include? and where should I build, in r.stream or in the the subdirectory r.stream/r.stream.basins?
Is there any mac specific configuration?
I want to intall it globally for all users (for compiling/installation my admin account will be used)
In ~/Library/GRASS and Library/GRASS there are no subfolders at the moment e.g. a Modules-folder.
I'm sure that your configuration error this time is because you need to
compile both 32+64bit. It's possible that the /usr/local part was ignored
and it configured from the system, then compiling and failing from ActiveTcl.
(the system Tcl has 64bit but it doesn't work in GRASS)
Restore my TclTk and add this to your configure:
--with-macosx-archs="i386 x86_64"
On Mar 1, 2011, at 2:39 AM, Johannes Radinger wrote:
> -------- Original-Nachricht --------
>> Datum: Mon, 28 Feb 2011 15:13:40 -0600
>> Von: William Kyngesburye <kyngchaos@kyngchaos.com>
>> An: Johannes Radinger <JRadinger@gmx.at>
>> Betreff: Re: [GRASS-user] Warning to Mac users: TclTk 8.5.9 breaks
compatibility for NVIZ
>> Hmm, because a couple items, TclTk and wxPython, are not available for
>> 64bit, you must configure for both 32bit and 64bit. The GRASS modules
will
>> still run 64bit, but TclTk and wxPython components will run 32bit only.
>> See that GRASS Mac readme for info on compiling for multiple
>> architectures.
> I am not sure if it has something to do with configure for 32bit and
64bit as the configure command was working before installing your tcl/tk.
> My configure options are:
> ./configure --with-freetype
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
/Library/Frameworks/FreeType.framework/unix/include"
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
--with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-proj
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --without-postgres
--without-mysql --with-odbc --with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
--with-cxx --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
/Library/Frameworks/Tk.framework/Headers
/Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs=/usr/local/lib --with-x --without-motif
--without-glw --with-opengl=aqua --without-readline --prefix=/Applications
--enable-macosx-app
--with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include"
--with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib
--with-cairo-ldflags=-lcairo --x-includes=/usr/X11R6/include --x-libraries=/usr/X11R6/lib
> A played a little bit around now and tried to build and install tcl
myself with following configure options (--prefix=/usr/local --enable-aqua
--enable-framework). I then tried also to built tk but I fail here...
> ...anyway, when I now run configure for grass it seems that there is now
problem with tcl..now I get (only) the error about the tk-library. It
really seems that your installer isn't working on my snowleopard.
> /johannes
>> On Feb 28, 2011, at 2:53 PM, Johannes Radinger wrote:
>>> Attached there is the config.log, I really don't know what it means...
>>> /johannes
>>> <config.log>
>>> Am 28.02.2011 um 18:02 schrieb William Kyngesburye:
>>>> OK. Look in config.log for details why the configure checks failed.
>>>>>> Datum: Mon, 28 Feb 2011 09:27:56 -0600
>>>>>> tclselect is a non-standard ActiveTcl thing, I think. That's
>> probably not
>>>>>> why it failed.
>>>>>> Did you download my 8.5.8-2 installer? That has an important
install
>> step
>>>>>> I missed the first time.
>>>>> yes I used the new 8.5.8-2 installer...
>>>>>>>> Datum: Mon, 28 Feb 2011 08:31:51 -0600
breaks
>>>>>>>> I shouldn't take 20m to prepare the installation, maybe there are
>> some
>>>>>>>> permissions problems? Try using Disk Utility to repair
>> permissions.
>>>>>>>> If you are still getting the error, it looks like the installer
>> didn't
>>>>>>>> overwrite ActiveTcl, maybe something to do with that 20m
preparing
>>>>>> time. Try
>>>>>>>> deleting these and reinstall mine (download again, I also added
>> some
>>>>>>>> missing install logic):
>>>>>>>> /usr/local/bin/tclsh
>>>>>>>> /usr/local/bin/tclsh8.5
>>>>>>>> /usr/local/bin/wish
>>>>>>>> /usr/local/bin/wish8.5
>>>>>>> I followed your instructions, and when I know run ./config
>>>>>>> I get following error:
>>>>>>> checking whether to use Tcl/Tk... yes
>>>>>>> checking for location of Tcl/Tk includes...
>>>>>>> checking for tcl.h... yes
>>>>>>> checking for tk.h... yes
>>>>>>> checking Tcl version... 8.5
>>>>>>> checking Tk version... 8.5
>>>>>>> checking for location of Tcl/Tk library... /usr/local/lib
>>>>>>> checking for Tcl_Init in -ltcl... no
>>>>>>> checking for Tcl_Init in -ltcl8.5... no
>>>>>>> checking for Tcl_Init in -ltcl85... no
>>>>>>> configure: error: *** Unable to locate Tcl library.
>>>>>>> I accidently deleted tclselect so probably that is the reason...I
>> don't
>>>>>> know were to get this file from...it seems that is not a part of
the
>>>>>> tcl-installer package.
>>>>>>> /johannes
>>>>>>>>>> Datum: Sun, 27 Feb 2011 09:53:06 -0600
>> breaks
>>>>>>>>>> Works here. Try this: after you run the installer, before
>> clicking
>>>>>>>>>> through the buttons, select Installer Log from the Window menu,
>> then
>>>>>>>> select Show
>>>>>>>>>> All Logs from the popup in that window. Now click through to
>> start
>>>>>> the
>>>>>>>>>> installation. Hopefully the last message in the log when it
>> stalls
>>>>>>>> will be
>>>>>>>>>> useful.
>>>>>>>>> Oh thank your for that info, I haven't noticed that function
yet.
>> It
>>>>>>>> seems that I was just to impatient, it took around 20 min to
>> prepare
>>>>>> the
>>>>>>>> installation (got stucked in the step where /usr is involved),
>> anyway
>>>>>> it says
>>>>>>>> that it is installed successfully now...
>>>>>>>>> ...but I still get the same error (even after a second
>> installation of
>>>>>>>> your TCL package, which was much faster):
>>>>>>>>> Errors in:
/Users/admin/Downloads/grass-7.0.svn_src_snapshot_2011_02_26/visualization/nviz
>>>>>>>>> and in that directory:
>>>>>>>>> make -C srcgcc -g -O2
-I/users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_26/dist.i386-apple-darwin10.6.0/include
>>>>>>>> -D_FILE_OFFSET_BITS=64
-I/Library/Frameworks/Tcl.framework/Headers
>>>>>>>> -I/Library/Frameworks/Tk.framework/Headers
>>>>>>>> -I/Library/Frameworks/Tk.framework/PrivateHeaders
>>>>>>>> -I/Library/Frameworks/UnixImageIO.framework/unix/include
>>>>>>>> -I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers
>>>>>>>> -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include
>>>>>> -DPACKAGE=\""grassmods"\"
>>>>>>>> -o OBJ.i386-apple-darwin10.6.0/togl.o -c togl.cIn file included
>> from
>>>>>>>> togl.c:53:/Library/Frameworks/Tk.framework/Headers/tkMacOSX.h:31:
>>>>>> error:
>>>>>>>> expected declaration specifiers or ‘...’ before
>>>>>> ‘TkRegion’togl.c: In
>>>>>>>> function ‘SetMacBufRect’:
>>>>>>>>> togl.c:1088: error: ‘struct TkWindowPrivate’ has no member
>> named
>>>>>>>> ‘grafPtr’
>>>>>>>>> togl.c: In function ‘Togl_CreateWindow’:
>>>>>>>>> togl.c:2221: warning: cast to pointer from integer of different
>> size
>>>>>>>>> togl.c:2338: warning: ‘aglSetDrawable’ is deprecated
(declared
>> at
>>>>>>>> /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
>>>>>>>>> togl.c:2340: error: ‘struct TkWindowPrivate’ has no member
>> named
>>>>>>>> ‘grafPtr’
>>>>>>>>> togl.c: In function ‘Togl_EventProc’:
>>>>>>>>> togl.c:2594: warning: ‘AGLDrawable’ is deprecated
>>>>>>>>> togl.c:2596: warning: ‘aglSetDrawable’ is deprecated
(declared
>> at
>>>>>>>>> togl.c:2610: warning: ‘aglSetDrawable’ is deprecated
(declared
>> at
>>>>>>>>> togl.c: In function ‘Togl_LoadBitmapFont’:
>>>>>>>>> togl.c:3143: warning: ‘aglUseFont’ is deprecated (declared
at
>>>>>>>> /System/Library/Frameworks/AGL.framework/Headers/agl.h:374)
>>>>>>>>> make[1]: *** [OBJ.i386-apple-darwin10.6.0/togl.o] Error 1
>>>>>>>>> make: *** [default] Error 2
>>>>>>>>> I am out of any ideas...
>>>>>>>>> /johannes
>>>>>>>>>> On Feb 27, 2011, at 4:25 AM, Johannes Radinger wrote:
>>>>>>>>>>> Am 26.02.2011 um 18:44 schrieb William Kyngesburye:
>>>>>>>>>>>> This really only applies to developers and users that compile
>>>>>> GRASS.
>>>>>>>> I
>>>>>>>>>> already bundle TclTk with my GRASS packages for those users
that
>> just
>>>>>>>>>> download and intall the binaries.
>>>>>>>>>>>> Anyways, I added a TclTk 8.5.8 installer to my site for those
>> that
>>>>>>>> need
>>>>>>>>>> it. Just a quick standard Aqua framework build, it'll
overwrite
>>>>>>>>>> ActiveTcl, and it takes care of the lib symlinks mentioned in
the
>>>>>> GRASS
>>>>>>>> Mac readme.
>>>>>>>>>>> I just tried your Tcl/Tk Installer, but it seems that it is
>> somehow
>>>>>>>>>> broken. I just get to the window "Preparing Installation" and
>> there
>>>>>> it
>>>>>>>> stops
>>>>>>>>>> and the installer is somehow frozen resp. doesn't continue to
do
>>>>>>>> anything...
>>>>>>>>>>> I work on snow leopard.. maybe you already know the problem
but
>> I
>>>>>> just
>>>>>>>>>> wanted to let you know..
>>>>>>>>>>> /johannes
>>>>>>>>>>>> On Feb 26, 2011, at 10:20 AM, William Kyngesburye wrote:
>>>>>>>>>>>>> Don't upgrade to TclTk 8.5.9, stick with 8.5.8. I realize
>> it's
>>>>>> been
>>>>>>>>>> out since last September, but I never upgraded out of laziness
>> and
>>>>>>>> didn't
>>>>>>>>>> notice.
>>>>>>>>>>>>> They switched to use the system Cocoa API from the old
Carbon
>> API
>>>>>>>>>> (should have saved that for 8.6). Togl still has Carbon calls
in
>> it,
>>>>>>>> and I
>>>>>>>>>> don't think that'll change (it's not an easy fix, and GRASS
still
>>>>>> uses
>>>>>>>> the
>>>>>>>>>> older togl 1.7, and even 2.0 still uses Carbon). I'm too lazy
to
>>>>>>>> report a bug
>>>>>>>>>> for TclTk on this - I don't use NVIZ and expect GRASS 7 (and
>> maybe 6)
>>>>>>>> to
>>>>>>>>>> eventually have something working in Python anyways.
>>>>>>>>>>>>> Unfortunately, ActiveState, that makes the ActiveTcl that is
>>>>>>>>>> recommended for compilation and my binaries, only provides old
>>>>>> versions
>>>>>>>> for download
>>>>>>>>>> for the "business" edition, and doesn't allow reditribution of
>> their
>>>>>>>>>> installers. I'll have to restore the TclTk compile
instructions
>> in
>>>>>> the
>>>>>>>> Mac
>>>>>>>>>> readme in the GRASS source, and figure out something to make a
>> TclTk
>>>>>>>> 8.5.8
>>>>>>>>>> available for existing GRASS packages.
>>>>>>>>>>>>> Any user-compiled or other distribution of TclTk 8.5.8 Aqua
>>>>>>>> frameworks
>>>>>>>>>> should work, as it's all just standard options in the source.
>>>>>>>>>>>>> Note: this only affects NVIZ. TclTk GUI is not affected.
>>>>>>>>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>>>>>>>>> http://www.kyngchaos.com/
>>>>>>>>>>>>> "I ache, therefore I am. Or in my case - I am, therefore I
>> ache."
>>>>>>>>>>>>> - Marvin
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> grass-user mailing list
>>>>>>>>>>>>> grass-user@lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>>>>>>> "The beast is actively interested only in now, and, as it is
>> always
>>>>>>>> now
>>>>>>>>>> and always shall be, there is an eternity of time for the
>>>>>>>> accomplishment
>>>>>>>>>> of objects."
>>>>>>>>>>>> - the wisdom of Tarzan
>>>>>>>>>> "History is an illusion caused by the passage of time, and time
>> is an
>>>>>>>>>> illusion caused by the passage of history."
>>>>>>>>>> - Hitchhiker's Guide to the Galaxy
>>>>>>>>> GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
>>>>>>>>> gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
>>>>>>>> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
>>>>>> fighting,
>>>>>>>> and all for things that the beasts of the jungle would not deign
to
>>>>>> possess
>>>>>>>> - money to purchase the effeminate pleasures of weaklings. And
yet
>>>>>> withal
>>>>>>>> bound down by silly customs that make them slaves to their
unhappy
>> lot
>>>>>>>> while firm in the belief that they be the lords of creation
>> enjoying
>>>>>> the only
>>>>>>>> real pleasures of existence....
>>>>>>> Schon gehört? GMX hat einen genialen Phishing-Filter in die
>>>>>>> Toolbar eingebaut! http://www.gmx.net/de/go/toolbar
>> fighting,
>>>>>> and all for things that the beasts of the jungle would not deign to
>> possess
>>>>>> - money to purchase the effeminate pleasures of weaklings. And yet
>> withal
>>>>>> bound down by silly customs that make them slaves to their unhappy
>> lot
enjoying
>> the only
>>>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>>>> - Marvin
>> "The beast is actively interested only in now, and, as it is always now
accomplishment of
>> objects."
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
"History is an illusion caused by the passage of time, and time is an
