[GRASS-dev] Website does not work with www for me
Howdie,
when I go to the GRASS website the lazy way without typing www (grass.osgeo.org), I can load the page without a problem. However, when I want to try it with www (www.grass.osgeo.org), I get the “Page not found” error message.
Is it just me? Is it normal? Is it internet mimicry? Is it something I should open an issue at [1] for?
Thank you,
Ondřej
[1] https://github.com/OSGeo/grass-website
Hi Ondrej,
never tried that before and indeed it does not work when typing the www neither in firefox nor in Chrome. I’d say it is worth an issue, yes
Thanks
Vero
El jue., 13 ago. 2020 a las 23:50, Ondřej Pešek (<pesej.ondrek@gmail.com>) escribió:
Howdie,
Thank you,
Ondřej
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Ondřej Pešek <pesej.ondrek@gmail.com> schrieb am Do., 13. Aug. 2020, 23:50:
Howdie,
It’s expected as we don’t have a DNS record for that
Thank you,
Ondřej
Do we want that, too? I’d find it confusing, with and without www. But let’s hear opinions!
On 2020-08-13 8:17 p.m., Markus Neteler wrote:
Ondřej Pešek <pesej.ondrek@gmail.com <mailto:pesej.ondrek@gmail.com>> schrieb am Do., 13. Aug. 2020, 23:50:
    Howdie,
    (grass.osgeo.org <http://grass.osgeo.org>), I can load the page
    (www.grass.osgeo.org <http://www.grass.osgeo.org>), I get the "Page
    not found" error message.
It's expected as we don't have a DNS record for that
    [1] for?
    Thank you,
    Ondřej
Do we want that, too? I'd find it confusing, with and without www. But let's hear opinions!
Absolutely, a DNS record for www.grass.osgeo.org is still needed
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
pá 14. 8. 2020 v 1:17 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
As so far more voices can be heard saying yes, I have opened an issue for that [1]. Feel free to tag the issue later with the wontfix label and close it, but at least there will be a record of that decision.
[1] https://github.com/OSGeo/grass-website/issues/219
I wouldn't bother, there is no need for www. www is appropriate for the
toplevel domain, not for the grass subdomain.
But if you do add support for www, make it redirect to grass.osgeo.org
to make it clear that that is the canonical URL, instead of adding www
as an alias.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
piektd., 2020. g. 14. aug., plkst. 02:17 — lietotājs Markus Neteler
(<neteler@osgeo.org>) rakstīja:
I would vote for setting up a wildcard DNS entry (*.grass.osgeo.org) +
redirect to grass.osgeo.org thus
any.domain.that.ends.with.grass.osgeo.org is a valid redirect to GRASS
main page. Subdomains with explicit DNS records are not affected by
wildcard entry.
Māris.
wildcard entry.
Beware that these days this also implies that SSL certificates need to
be available for these subdomains as well. While Let's Encrypt has
wildcard support, it's much more limited than an explicit list of
subdomains.
Kind Regards,
Bas
However, when I want to try it with www (www.grass.osgeo.org), I get the "Page not found" error message.
later with the `wontfix` label and close it, but at least there will be a record of that decision.
So, isse kindly solved by Regina, thanks!
Should be resolved at - https://trac.osgeo.org/osgeo/ticket/2495
just redirected https://www.grass.osgeo.org and grass.osgeo.org to https://grass.osgeo.org.
Works smoothly now.
