Submitted by Paul Schrum
Also available at Integration Of PDAL into GRASS GIS
- What did you get done this week?
- Built GRASS73 from source from my local repo directoy.
- Stepped into a module (v.in.ascii) using the debugger to watch it work at the source code level. This was only proving the concept of stepping into the code – just getting it to work.
- Talked with my mentor about the nature of the existing v.in.pdal module and what are some of the things which must be changed, fixed, or improved.
- What do you plan on doing next week?
- Continue stepping through v.in.ascii to see how it works at the source level in order to understand how to write points to a vectormap.
- Get GRASS 73 to link to current version of PDAL.
- Fix broken references to PDAL data structures in the GRASS source
- Refactor existing v.in.pdal so that operations which r.in.pdal and r3.in.pdal will need are in a separate module and available as functions to be called from all three of them.
- Learn the process of calling PDAL and how to get it to do the basic operation of reading a lidar file and handing over the data to the caller.
- Set up a basic set of test data for PDAL, open it from pdal without GRASS, then open it using pdal through GRASS with only the most basic options in operation.
- Get PDAL to be able to read .laz (compressed) files. For some reason it can’t do that after build-from-source.
- Are you blocked on anything?
I had two listed on the Wiki when I originally posted it, but my mentor helped me work through those before the end of the reporting period for Week 1. So there are currently no issues blocking me.
