Hello Community,
I am sending my report for Week 11 (August 10-August 16). The report can also be found in the project wiki: https://trac.osgeo.org/grass/wiki/GSoC/2020/StartupWindow .
1) What did I complete this week?
I finished implementing the very important PR which distinguishes mapsets by ownership and lock (see https://github.com/OSGeo/grass/issues/714, https://github.com/OSGeo/grass/pull/849). I also fixed a bug that appeared when a user wanted to display a map from a different location (see https://github.com/OSGeo/grass/issues/884, https://github.com/OSGeo/grass/pull/886). Eventually, it is not allowed to do that and a user needs to switch a mapset first.
Currently, there are 3 other PRs that are in the process:
- Start in a demo/startup location (see https://github.com/OSGeo/grass/issues/862, https://github.com/OSGeo/grass/issues/897, https://github.com/OSGeo/grass/pull/868)
This issue was a bit broadened. It consists of not only creating a startup location but also a startup mapset. This PR also gives the option to start up whole GRASS GIS without the startup screen.
- Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog (see https://github.com/OSGeo/grass/issues/801, https://github.com/OSGeo/grass/pull/904)
Almost done, just some smaller cosmetic changes. This PR creates new checking functions that check both mapsets and locations when renaming/deleting.
- Switch to another mapset when in use (aka force remove lock) (see https://github.com/OSGeo/grass/issues/898, https://github.com/OSGeo/grass/pull/906)
Almost done, this issue offers an option to force the removal of the lock and switch to the mapset anyway.
2) What am I going to achieve for next week?
I am gonna end up those above-mentioned PRs. Then, I am gonna reflect changes, I made in Data Catalog, in GUI.
- Reflect changes done from Data Catalog in GUI and vice versa (see https://github.com/OSGeo/grass/issues/885)
- when map is renamed in data catalog while it is displayed, the layer needs to be changed otherwise rendering fails
- when map is moved elsewhere in data catalog while it is displayed
- new map is created (this item needs to be expanded, there are multiple ways a new map is created)
- current mapset/location is changed from menu
- etc.
3) Is there any blocking issue?
No, it is not.
Any suggestions are welcome.
Linda Kladivova
