- What did you get done this week:
I have been working on computing flow accumulation. I have a simple version working and a more precise way is almost ready. I also tried to support different combination of inputs and outputs to make the module convenient to use. More on the wiki [1]. The code is here [2].
- What do you plan on doing next week?
I will be traveling so I expect to do mostly testing and running it on real data. I also need to discuss further steps with mentors.
- Are you blocked on anything?
No.
[1] http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
