[GRASS-dev] Week 9 report: Creation of a new GRASS GIS startup mechanism
Hello Community,
I am sending my report for Week 9 (July 27-August 2). The report can also be found in the project wiki: https://trac.osgeo.org/…dow.
1) What did I complete this week?
I added two icons avaliable in the context menu: download sample location, create new location (see ​https://github.com/OSGeo/grass/pull/830). Currently I am working on 5 other PRs.
I set new mapset node properties: lock and user: Our motion is that those mapsets will be displayed in Data Catalog in gray and also distinguished by labels. I have an error which is probably somehow relates to my new keys definition, but do not know how to figure that out.
Within this PR I made two functions for deleting grassdb from the disk and removing grassdb from the tree. In this PR I also changed a bit checking if wanted grassdb is not already added to Data Catalog. All these functions = adding, removing and deleting grassdb change the wx file so that we can remember which grass databases are in the Data Catalog. Saving grassdatabase string to this file works but I have a problem when I starting GRASS GIS for the second time it falls down because it does not probably like the edited wx file.
This PR is ready for review. I added checking of current mapsets and location when deleting and renaming. The motion is that when Allow editing mode is ON we are allowed to rename and delete any mapsets and locations except current ones, if OFF no mapset or location can be renamed or deleted.
Here I made two functions startup_location_exists which checks for demolocation and copy_startup_location which copy the simple location with some data into GRASS database. I have a problem with testing that.
I am not stuck here but need some feedback if the icons I suggested are good, reasonable or something entirely different is needed.
2) What am I going to achieve for next week?
I am gonna end up those above-mentioned PRs. It was decided that the startup screen is no longer used. It has changed quite significantly the next GSoC steps. Now there are several issues related to the Data Catalog I am gonna address. They come from Next steps in GSoC and beyond video call, July 15, 2020 written by Vaclav Petras (see ​https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/New_Startup#NextstepsinGSoCandbeyondvideocallJuly152020):
  • Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog (​https://github.com/OSGeo/grass/issues/801)
  • Add buttons to add new things: Import into current mapset (also as a context menu item on mapset, see below).
  • Add context menu items: Import into mapset (like in File), Export map (like in Layers)
  • An icon for creating the new database
  • Deleting more than one location
3) Is there any blocking issue?
No. It is not.
Any suggestions are welcome.
Linda Kladivova
