- What did you get done this week?
The original plan for this week was to do a basic implementation of testing framework. However, I decided to start from the implementation available in Python unittest. This allowed me to continue in work on design implementation problems. I also studied the unittest implementation to understand what are the places which will be different in GRASS testing framework.
- What do you plan on doing next week?
The plan is to test unittest and doctest methods for evaluation and comparison of textual and numerical outputs (results) on GRASS use cases.
- Are you blocked on anything?
During next week, I (we) will need to make a decision if the tests will be limited to English language environment (or even English locales) because this can influence significant part of textual output comparisons.
Vaclav
http://trac.osgeo.org/grass/wiki/GSoC/2014/TestingFrameworkForGRASS#Week02
