[GRASS-dev] Weekly report 3: Testing framework for GRASS GIS
  1. What did you get done this week?
The plan was to test unittest and doctest methods for evaluation and comparison of textual and numerical outputs (results) on GRASS use cases. The simple cases are solved by unittest. Besides the code I put to sandbox I wrote some tests of some functionality related to g.list [1], g.mlist and g.mremove.
I discovered several functions in grass.script.core which can be used to solve more complex outputs of modules. So, I copied them, generalized them and wrote a tests for them (more work is needed). These functions can be used later to write tests but also in GRASS itself.
Regarding the issue with testing using different languages (translations). With the tests I wrote [2] is seems that the best solution will be to use regular expressions or just Python in operator to test if the message contains the required information. In other words, test should be independent on language environment.
I also explored the the possibility of using code coverage to evaluate the tests. It seems that with Python coverage package [4], we can get code coverage (reports) for Python library without much burden at least for basic cases (no modules involved, no ctypes).
  1. What do you plan on doing next week?
The plan is to implement some way or ways of comparison of raster and vector maps. It would be good to implement comparison of other things too and to finish comparison of textual and numerical outputs from this week but the topic is so complex that I will focus just on raster maps first.
  1. Are you blocked on anything?
The fact that I also have to create the some tests to test the framework on some real world example slows me down but on the other hand, it is necessary and even very useful because I’m also testing things, such as the functions which will be used for creating the tests. And I discovered some problems right away.
Vaclav
[1] http://trac.osgeo.org/grass/browser/grass/trunk/general/g.list/test_g_list.py?rev=60619
[2] http://trac.osgeo.org/grass/attachment/ticket/2228/test_g_mremove.py
[3] http://trac.osgeo.org/grass/changeset/60730
[4] https://pypi.python.org/pypi/coverage
http://trac.osgeo.org/grass/browser/sandbox/wenzeslaus/gunittest?rev=60733
http://trac.osgeo.org/grass/wiki/GSoC/2014/TestingFrameworkForGRASS#Week03
