[GRASS-dev] Weekly snapshot - link with non-changing name?
Hi
I have a homebrew recipe for installing grass 7.1 on a Mac. But whenever
I want to update to a new weekly snapshot, I have to change the URL from
which to download the weekly snapshot.
Would it be possible to add a link, e,g,
| http://grass.osgeo.org/grass71/source/snapshot/grass-7.1.weekly_snapshot.tar.gz
so that the URL used can stay the same?
Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
On Fri, Jun 19, 2015 at 10:42 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi
Yes, done:
--> grass-7.1.svn_src_snapshot_latest.tar.gz
this is a link to the latest snashot file.
Markus Neteler <neteler@osgeo.org> writes:
Hi
Yes, done:
Perfect - thanks.
Rainer
Rainer M. Krug
PGP: 0x0F52F982
Rainer M Krug <Rainer@krugs.de> writes:
Hi
Yes, done:
Perfect - thanks.
Quick follow up - is the weekly snapshot supposed to be more stable than
the svn version, or is is simply a snapshot taken automatically once a
week?
Rainer
Rainer
Rainer M. Krug
PGP: 0x0F52F982
wrote:
>>> Hi
whenever
from
>> Yes, done:
> Perfect - thanks.
week?
The latter. It is really just a automatic snapshot, not a tested release.
Vaclav
Rainer
> Rainer
>> Markus
Rainer M. Krug
PGP: 0x0F52F982
grass-dev mailing list
grass-dev@lists.osgeo.org
Vaclav Petras <wenzeslaus@gmail.com> writes:
wrote:
>>> Hi
whenever
from
>> Yes, done:
> Perfect - thanks.
week?
release.
Thanks - so I will then use HEAD of the svn - easier to do in homebrew,
as no sha hash is needed of the downloaded file.
Rainer
Vaclav
Rainer
> Rainer
>> Markus
Rainer M. Krug
PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
release.
You want me to generate that?
Rainer
Vaclav
Rainer
Rainer
Rainer M. Krug
email: Rainerkrugsde
PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
> release.
No - no need. I just tell homebrew to download head from svn and than to
compile it - it works.
I will post a link to the recipe later this week. This will make testing
of GRASS 7.1 easy on OS X.
Thanks a lot,
Rainer
Rainer
> Vaclav
> Thanks,
>> Rainer
>> > Rainer
>> >> Markus
>> Rainer M. Krug
>> PGP: 0x0F52F982
>> _______________________________________________
Rainer M. Krug
PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
>> > release.
And it can be combined with:
    cd /grass/source/code/root
    ./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ \
        --exec python -m grass.gunittest.main \
        --location nc_spm_08 --location-type nc
Thanks a lot,
Rainer
> Markus
>> Thanks,
>> Rainer
>> > Vaclav
>> > Thanks,
>> >> Rainer
>> >> > Rainer
>> >> >> Markus
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Hi Vaclav,
>> > release.
That is a brilliant idea. But as the tests will be run automatically, I
need to download the data.
I assume this is the dataset to be used:
http://grass.osgeo.org/sampledata/north_carolina/nc_spm_08_grass7.tar.gz
Is this correct?
Rainer
Thanks a lot,
Rainer
> Markus
>> Thanks,
>> Rainer
>> > Vaclav
>> > Thanks,
>> >> Rainer
>> >> > Rainer
>> >> >> Markus
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
On Fri, Jun 26, 2015 at 4:52 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi Vaclav,
>> >> > release.
homebrew,
The download could be added to test execution but I'm not sure about that.
It would just make it more complex.
Is this correct?
Yes. Although, there are some inconsistencies (some test fail because they
expect the basic nc spm). However, this all should change because we should
switch to the new sample dataset naming scheme [1]. Needless to say,
volunteers needed.
Vaclav
[1] https://trac.osgeo.org/grass/wiki/SampleDataset
Rainer
> Thanks a lot,
>> Rainer
>> > Markus
>> >> Thanks,
>> >> Rainer
>> >> > Vaclav
>> >> > Thanks,
>> >> >> Rainer
>> >> >> > Rainer
>> >> >> >> Markus
>> >> >> Rainer M. Krug
>> >> >> PGP: 0x0F52F982
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Hi Vaclav,
>> >> > release.
homebrew,
I added the sample data as a separate recipe so that the instrallation
is independent.
Is this correct?
volunteers needed.
Just let me know when there are changes.
Rainer
Vaclav
Rainer
> Thanks a lot,
>> Rainer
>> > Markus
>> >> Thanks,
>> >> Rainer
>> >> > Vaclav
>> >> > Thanks,
>> >> >> Rainer
>> >> >> > Rainer
>> >> >> >> Markus
>> >> >> Rainer M. Krug
>> >> >> PGP: 0x0F52F982
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Hi Vaclav,
>> >> > release.
homebrew,
Is this correct?
volunteers needed.
Is (or will) the dataset be on a svn or git? This would make always
using the latest one very easy.
Rainer
Vaclav
Rainer
> Thanks a lot,
>> Rainer
>> > Markus
>> >> Thanks,
>> >> Rainer
>> >> > Vaclav
>> >> > Thanks,
>> >> >> Rainer
>> >> >> > Rainer
>> >> >> >> Markus
>> >> >> Rainer M. Krug
>> >> >> PGP: 0x0F52F982
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Perhaps to be added here
http://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html#running-tests-report
